      09-26-2012, 02:43 PM   #1
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
1/2 quart more oil????
I was wondering about this. When I tracked my E30 M3 for the 6 years I had it, I always overfilled the engine oil by about 1/3-1/2 quart of oil. In the S14 engine this prevented oil starvation on hard cornering and braking. This was a commone practice with everyone. Does the S54 need to be treated the same way?
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      09-26-2012, 02:56 PM   #2
The HACK
Roger Murdock
The HACK's Avatar
872
Drives: 2006 MZ4C, 2015 Fiat 500e
I believe the S54 comes with a "semi-dry" sump design, where the wet sump in complimented by a secondary oil pump, or the dry-sump to prevent the oil starvation problems common with 100% wet sump designs of the not so distant past.
I don't think overfilling would be helpful on this engine.
The hell I don't! LISTEN, KID! I've been hearing that crap ever since I was at UCLA. I'm out there busting my buns every night! Tell your old man to drag Walton and Lanier up and down the court for 48 minutes!
-Roger Murdock
      09-26-2012, 02:56 PM   #3
Incompatible
Drives: 07 AW Z4C 3.0Si
Good question, I'll jump in and ask the same for the N52?
I know you don't want to much of an overfill which will create other problems. Is there a "sweet spot" for overfill with our cars or does it really matter?
      09-27-2012, 11:20 PM   #4
seank
enthusiast
seank's Avatar
39
Good question. I was told if I was going to start to track the car regularly, that I should upgrade the oil pump. Something similar to the e30m3 track car?
      09-27-2012, 11:31 PM   #5
Kgolf31
Kgolf31's Avatar
361
Drives: 2007 Z4MC, 2012 128i
This. Same thing I've found out about our engine as well.
On wet sump engines, people usually put close to a quart over (mostly to avoid lifter tick).
With maintaining accurate oil levels (3/4 on the dipstick range). I never got lifter tick on any autocross day or track day.
