Reply
      06-12-2012, 02:49 PM   #1
mousitch
Dark Sider
mousitch's Avatar
Drives: 2008 Space Gray Z4MC
Send a message via Yahoo to mousitch
Noise from AUX input
Anyone get feedback/noise from the stock AUX input under the dash? When ever I plug in there is a lot of hissing/noise . If I move the plug around I can make the noise somewhat less. Its like the Aux input is loose as I can kinda of move it around. Anyone else see/hear this issue?
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Escort 9500ix-BMW CCA Member-ST Louis Chapter
mousitch is offline   United_States
      06-12-2012, 09:43 PM   #2
Stromtech
Stromtech's Avatar
Drives: 2004 Z4 3.0i 6-speed Sport
First thing I would try is another cable between the aux jack and the MP3 player...could be a bad cable
Next pop the panel and check the connections on the jack itself.
Stromtech is offline   Reply With Quote
      06-12-2012, 11:16 PM   #3
mousitch
Dark Sider
mousitch's Avatar
Ill try that. Any word on how hard it is to pop that panel?
      06-13-2012, 08:54 AM   #4
Stromtech
Stromtech's Avatar
It just pops off....I use a plastic putty knife so I don't scratch the plastic panel. This might help you out:
http://www.z4-forum.com/forum/viewto...p?f=31&t=15087
      06-13-2012, 10:33 AM   #5
mousitch
Dark Sider
mousitch's Avatar
Thank you!
      06-13-2012, 02:26 PM   #6
elerner61
elerner61's Avatar
Drives: '07 Z4M Roadster
If I recall, the plastic retainers on the top and bottom of that panel are different. The ones along the top are meant to be fitted first and the ones along the bottom are angled and meant to be "pushed" in next (or vice versa). So, try and pop the lower edge first (I am able to just use my fingertips/nails) and see if that pops it easily. If not, then try the upper one. The plastic used is not very hard,, the panel flexes so you should not have to exert a lot of force to get that panel off.
elerner61 is offline   Reply With Quote
      06-13-2012, 04:36 PM   #7
carelessmoker
carelessmoker's Avatar
Drives: 2007 Z4 MR
2007 MR  [0.00]
I have the same issue. Same noise with both my wife and my iPhone 4. Been meaning to try another cable just need to get out to get one. Will let you know if it does any good.
carelessmoker is offline   United_States
      06-13-2012, 05:51 PM   #8
Stromtech
Stromtech's Avatar
I use a cable I got off Ebay that connect to the Iphone Dock Port. It has both a mini jack and a USB on the other end to connect tot he car. This works much better than using the headphone jack output. The cable was only a couple of bucks.
Here is one like mine:
http://www.ebay.ca/itm/USB-3-5mm-AUX...item27b7582ac8
      07-04-2012, 06:41 PM   #9
pyo
Drives: 2004 Z4 3.0i 6spd
http://www.amazon.com/gp/aw/d/B00509DPPS/ref=mp_s_a_6?qid=1341445153&sr=8-6
I have this exact cable. iPhone dock to USB and 3.5mm line out. No hissing/feedback even while charging.
'04 Z4 3.0i 6sp AW w/ Dream Red - Stubby Antenna, OE Clear Kit, OE Front Aero, OE E46 Aux Kit, Smoke Tinted Front Ambers, Sound Gen Mod, Matte Black Grills, RPI Red Air Scoop, Dinan CAI, Windblox Screen, gapTech RCH+, CDV Delete, Clutch Stop, RE Race Brace, USMillWorks Front Plate Tow Hook, AutoSolutions SSK, ZHP Knob,
pyo is offline   United_States
      07-05-2012, 06:37 AM   #10
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
I had the same issue and was convinced the jack was coming loose but had a spare cable and tested it. Sure enough the cable was the issue.
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
Reply
Forum Jump
