Go Back   ZPOST > Marketplace > Sponsors Classifieds
Reply
      06-07-2012, 12:51 PM   #1
Andrew@IND
Andrew@IND's Avatar
Drives: BMW
iND | Macht Schnell MS97 Spec Shifter Knob
Finally, a more aggressive knob made for the BMW shift lever. The Macht Schnell MS97 knob stands at 97mm in height allowing for a more efficient shift motion all the while bringing the knob closer to the 3 o'clock hand position. As a result the driver can focus less on shifting the vehicle and more on steering input. The knob is machined using 6/6 nylon which means less heat transfer from the aluminum shift lever and reduced NVH.
The knob is a pressure fit and does not require any screws. For clients with the 1 piece OEM knob and boot modification/trimming is necessary.
Macht Schnell MS97 Spec Shifter Knob - $89.00 MSRP
IN STOCK AND READY TO SHIP!
  • SKU: 50.20.097
  • Black nylon 6/6 construction
  • 97mm height
  • BMWs with a 1-piece shift knob/boot will require modification
Andrew@IND is offline
      06-07-2012, 02:43 PM   #2
Beedub
ya no... i think this would be PERFECT but i think they missed a trick by not engraving the shift pattern on the top..... Theirs more than enough space... also does nylon mark easily, so if im wearing a ring is this thing going to look like shit in a few months??
product looks nice, any weight info???
Pristine Bi-colour Ti /Bsm...z4m roadster Ess vt2-500....Perfection on wheels.
Beedub is offline   United Kingdom
      06-07-2012, 02:56 PM   #3
Andrew@IND
Andrew@IND's Avatar
Drives: BMW
Ah, right hand drive. The ring thing makes a lot of sense.
Weight was roughly .2lbs (90grams) on our UPS scale.
Andrew@IND is offline   Reply With Quote
      06-20-2012, 05:55 PM   #4
Andrew@IND
Andrew@IND's Avatar
Drives: BMW
Shift knobs in stock and ready to rock!
Reply
Search this Thread:
Advanced Search
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
