Reply
      05-09-2012, 04:57 PM   #1
mfanatic325
///M-fanatic
mfanatic325's Avatar
Drives: '07 Z4MC, '04 325Ci
Send a message via AIM to mfanatic325
Volk Wheel Hubcentric Rings
Just putting this here for those that have Volk wheels and might be needing hubcentric rings. I've already done some research for you folks
What you'll need are FOUR (4) 75mm --> 72.56mm rings. I'd recommend getting aluminum/metal hub rings if you do any tracking at all, as cheaper plastic ones will melt at track temps.
You can order hubcentric rings from various online vendors, but here's one to start off the thread:
https://www.1010tires.com/store/p-93...-set-of-4.aspx
Just for reference, I personally spent about $50 USD for a full set of four aluminum rings, shipped to me.
Good luck, and let me know if you have any questions. Happy motoring!
VF570 S/C|TIAL BOV|SetRabCooler|Brembo GT 6/4|TE37s|NT05s|3.91 Gearing|TCK D/A|RPi Induction|SS Race Mufflers/X-pipe|JVT Headers|AS SSK|Sparco Pro2000/6pt.Harness|MS FloorMounts|SE Custom Harness Bar|Tekarbon Angels|M-Tech Pedals|OE Strut Bar|RE RSMs|8000K D2S|CDV DEL|CF Roof Wrap|MB Grills|UUC TrannyMounts/ClutchStop|V1 Mount|P3C Gauge
mfanatic325 is offline   Taiwan
      05-09-2012, 05:45 PM   #2
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Did you have to replace plastic ones or something?
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
      05-09-2012, 06:14 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
Some Volks come in the right hub size
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      05-09-2012, 06:23 PM   #4
mfanatic325
///M-fanatic
Yup! The ones that came with my wheels upon purchase were urethane ones, which were already an upgrade from normal plastics, but they too couldn't take the heat. And I also got some PM's regarding the topic so I figured I'd post it up for the good of all that read
Oh do they now? Because I was under the impression-from some quick research-that Volk just did 75mm center bores for all BMWs, since that way it's less work on them and they have a one size fit all application. Apparently some 5-series have slightly larger hub bore than the usual 72.6mm
      05-09-2012, 06:28 PM   #5
Daemonblitz
Commander
Daemonblitz's Avatar
Drives: Imola/Imola Z4MC
2006 Z4M Coupe  [4.27]
E39 5-series, current gen X5s and current gen X6s (only on the front) have the oversized hubs. All others 5 bolt BMWs are the 72.6mm
Daemonblitz is offline   Romania
      05-09-2012, 06:30 PM   #6
mfanatic325
///M-fanatic
^ There we have it folks! Goes to show that I'm not just spewing a load of BS
      05-09-2012, 06:33 PM   #7
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
SuperSprint Race Cans, RE X Pipe, Fabspeed Headers, OE STB, AS Shifter, Dave Z Modified CDV, Ground Control Coil Overs, Stoptech lines, Stoptech Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, ZHP Shift Knob, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
Caddyshk is offline   Canada
      05-09-2012, 06:36 PM   #8
mfanatic325
///M-fanatic
      05-09-2012, 09:44 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
I'm not sure why they did it but my VR.G2 are made with 72.6
      05-09-2012, 11:02 PM   #10
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Actually intgr8r and daemon are both right, yes not all BMW hubs are the same. But Volks requiring hubcentric rings doesn't really have to do with that. When Volks released wheels for BMW, I'm almost certain the fitments were not meant for the e39 so they all require hubcentric rings. But every once in a while you may come across a set of special order wheels that are already hubcentric.
One example: http://forum.e46fanatics.com/showthread.php?t=804763
      05-10-2012, 12:24 AM   #11
mfanatic325
///M-fanatic
Those hubcentric Volks must have been custom-ordered/made. Others--part of Volks' typical run batches--were bored to 75mm for one-size fits all applications (with the use of hub rings of course)
Everyone's right in here. Why are we so damned smart? Can't we be wrong for once?
      05-10-2012, 06:59 AM   #12
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
The correct hub size is one of the features of the VR.G2.
With the G2 they do it for all the various model fitments.
I guess it's just a feature of this particular Volk wheel .
http://www.rayswheels.co.jp/2009/pro...-18&for=import
      05-10-2012, 10:06 AM   #13
ZStig
Drives: VT2-500 M Roadster
OP's link not working on my work computer, will try at home. thanks
ZStig is offline   Reply With Quote
      05-10-2012, 10:38 AM   #14
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
As long as we're all right and you're wrong!
      05-10-2012, 10:40 AM   #15
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
      05-11-2012, 01:46 AM   #16
mfanatic325
///M-fanatic
      05-11-2012, 12:55 PM   #17
ZStig
Ffs they won't ship to my address in PA. WTF
      05-11-2012, 02:28 PM   #18
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Will they ship to nj? If so I'll ship to you.
      05-11-2012, 03:44 PM   #19
mfanatic325
///M-fanatic
Wow, that's unfortunate Rofflz. Bad luck I suppose...
      05-11-2012, 04:39 PM   #20
ZStig
ok its working now, ordered. thx
      05-11-2012, 11:23 PM   #21
mfanatic325
///M-fanatic
Good to hear. I should be getting mine in another week or so (assuming they sent the rings via ground shipping).
      05-15-2012, 08:09 PM   #22
mfanatic325
///M-fanatic
I got my rings in today and surprisingly they're blue anodized
I personally don't mind, since I currently have blue lugs, and there's some blue Volk stickers on my wheels. Plus, you can't really see the hub ring once installed anyhow.
I swapped my old warped and cracked urethane-plastic rings out with these aluminum ones and went for a test drive. Found a noticeable decrease in wheel vibration and smoothness
Reply
Search this Thread:
Advanced Search
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
