Reply
      04-16-2012, 10:35 PM   #1
jdl1pt
Drives: Z4M coupe 2007 IL Blue
Help Needed, front wheel frozen to the hub!
Hey all,
I just bought new wheels and was getting ready to put them on when I found that my drivers front wheel seems to be frozen to the hub. And yes I had all the lugs off... I've had it off a few times before, but this time it just didn't budge. I only had a scissor jack so didn't want to lay into it hard, but at the end I was giving it everything I've got. Is it possible for the hub to rust to the wheel and fuze?
I tried, rubber mallet, WD40 around the inner and outer hub, and lots of elbow grease and nothing.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
jdl1pt is offline
      04-16-2012, 10:40 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
Pb blaster ?!
dorifto88 is offline   Reply With Quote
      04-16-2012, 10:47 PM   #3
Finnegan
Finnegan's Avatar
Had this happen too. Took a 2x4, padded it (towel), gave the 2x4 a tap with my 10 lb sledge. The 2x4 was a 16" section, and the 16" were between the sledge and the edge of the wheel/tire. It just needed a tap (not a whack).
2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047
Finnegan is offline   United_States
      04-16-2012, 10:48 PM   #4
Daemonblitz
Commander
Daemonblitz's Avatar
Drives: Imola/Imola Z4MC
2006 Z4M Coupe  [4.34]
My suggestion is put one of the lugs back on partially so the wheel doesn't fly off when it eventually does come off and keep at it with that rubber mallet from the inside part of the wheel. And next time throw on just a bit of high-temp anti seize around the hub so you don't have this issue in the future
Edit: Padded 2x4 + rubber mallet sounds a bit better than my original suggestion like Finnegan says.
Daemonblitz is offline   Romania
      04-16-2012, 10:48 PM   #5
jdl1pt
Originally Posted by dorifto88 View Post
Pb blaster ?!
??? please expand
Thanks!
jdl1pt is offline   Reply With Quote
      04-16-2012, 10:49 PM   #6
jdl1pt
never mind found it http://www.pbblaster.com/
Ron I'm not quite following you, was the 2x4 on the inside or outside of the wheel, or between the spokes ?
Will use the anti seize next time, great idea.
Thanks both!
      04-16-2012, 11:22 PM   #7
seank
enthusiast
seank's Avatar
Anti sieze wont work at those temperatures. Just anti squeak grease, like you put behind your brake pads. CV joint grease is also good at high temperatures.
seank is offline   Reply With Quote
      04-16-2012, 11:44 PM   #8
Bayonet
Drives: Z4 Mc
had this happen a few times....a stable floor jack and a good kick should do the trick
Bayonet is offline   Reply With Quote
      04-17-2012, 12:04 AM   #9
jdl1pt
Thanks for the info. BTW, you heading down Sat?
Well a "stable" floor jack was an issue, but thanks to Amazon 1day shipping, it won't be come Wed!!! Just picked this up. http://www.amazon.com/OTC-1532-Capac...4638803&sr=8-1
      04-17-2012, 12:39 AM   #10
Finnegan
Finnegan's Avatar
Thanks both!
John, outside edge of the wheel right next to the tire. Gives the tap some leverage. Bayonet's approach essentially does the same thing, I just felt I had more control with the tap. The sharp shock plus leverage knocks it free. I have one of these which is handy for things like this (wheel won't drop) and it makes putting the wheel back on much easier when working by yourself.
      04-17-2012, 01:21 AM   #11
jdl1pt
I'm with you now.
I saw the wheel pin long ago. Now that I have a second set of rims, and may be swapping more often, I may pick one up.
Pics of the new rims mounted will be up Thursday (fingers crossed)
      04-18-2012, 11:41 PM   #12
elerner61
elerner61's Avatar
Drives: '07 Z4M Roadster
Had this happen on a couple of cars. I use what I call "Donkey Kicks". Get on your butt sitting in front of the wheel and give some swift kicks with both feet on the lower edge of the wheel/tire!
elerner61 is offline   Reply With Quote
      04-19-2012, 12:12 AM   #13
jdl1pt
The rubber mallet to the back of the wheel finally did the trick!
Thanks everyone for your thoughts, this forum is awesome!
Reply
Forum Jump
