FORUMS
- 5
| 10-28-2011, 06:01 PM | #1 |
Topsider Oil Extractor
Got it in the mail a few days ago and decided to change my oil today since it was due. I searched the entire forum and didn't see any threads on it.
Fairly easy to use it, but I found I had to pump every 5-10min to keep the oil going. Think it took me 35-40min to fully drain it out. Also believe I got all the oil out, logic behind that is I put back in 5.5litres of oil and the dip stick was showing between half and full. From what I've read on here our engine takes 5.5-6.0litres. Why I like it 1. No mess 2. Easy to do 3. Don't have to lift the car or get under it at all ![]() I have read on other forums that people dislike it for not getting all the oil out and others loving it for the reason's I posted above. |
| 10-28-2011, 10:45 PM | #3 |
![]() ![]() Drives: Sapphire Black/Black Z4Mc Join Date: Oct 2008
^WHS
I'm interested in what happens after 6 months. Other extractors (Mitivac) have failed due to some interaction between synthetic oil and the seals.
![]() 2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047 |
| 10-29-2011, 10:30 AM | #5 |
Picked it up from Northern Tools for $50 plus shipping ($89 CAD total). They also ship to Canada. My package came from Burlington, so no duty but there is tax.
Will see how it holds up over the year as I use it and report back. http://www.northerntool.com/shop/too..._390306_390306 I saw that Bimmian has one as well but they want $114 plus tax and shipping for it. |
| 10-29-2011, 02:00 PM | #6 |
![]() ![]() ![]() Drives: 2004 ESS TS2 Z4R Join Date: May 2011
I guess i dont see the point of this? Is it just to save a mess? For example on post you're on authorized to change your oil in your driveway so I'm assuming you would use this then?
| 10-29-2011, 05:34 PM | #7 |
![]() ![]() ![]() Drives: 2007 Z4 M Coupe Join Date: Sep 2008
Me neither. Two pieces of 2x6, jack and jackstands (for safety) i will be done in 15 minutes.
| 10-30-2011, 11:00 AM | #8 |
![]() ![]() ![]() ![]() Drives: '04 X5, '08 Z4MC Join Date: Apr 2010
Unless the car is placed on 4 jack stands (or you lowered the car back down to level ground during draining if only jacking up from the front), you may not be able to get as much oil drained if the car sits at an angle with just the front on jack stands. In this case, the extractor may get more oil out than the 2 jack stand method. I like the draining method much better as I feel that it gets more of the "crud" out from the bottom of the pan, but with the Z being so low, the extraction method is awfully tempting.
| 10-30-2011, 12:02 PM | #9 | |
As someone already mentioned, it is a good alternative if one has no access to jack, jackstand, etc.. My point was that I could do a much better and quick oil change by draining it. |
| 11-06-2011, 09:18 PM | #10 | |
| 11-06-2011, 10:10 PM | #11 | |
| 11-15-2011, 05:12 PM | #12 | |
| 04-14-2012, 06:23 PM | #14 | |
No issue with seals. I think it went quicker this time around. It wasn't as cold out as it was in October. It sucked out all 5.5litres. Will report back again in 6 months when I expect to do next oil change. Hopefully it still works then . lol |
| 04-14-2012, 08:07 PM | #15 |
M = Midlife Crisis
Drives: 2006 Z4MC Interlagos Join Date: May 2007
Mityvac = 10 minutes. Measured Oil removed = 5.5 L
2006 Z4MC - #LL93158
SuperSprint Race Cans, RE X Pipe, Fabspeed Headers, OE STB, AS Shifter, Dave Z Modified CDV, Ground Control Coil Overs, Stoptech lines, Stoptech Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, ZHP Shift Knob, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
| Bookmarks |
