Reply
      04-08-2012, 09:29 PM   #1
RandysV10
MPOWERD
RandysV10's Avatar
Drives: 2010 M6
2006 Z4M  [0.00]
2010 BMW M6  [0.00]
Easter RTABs
So I tackled the RTABs today, went with the Powerflex Polys. Installation wasn't to bad, just somewhat time consuming.
Removed the inner liner covers, supported the trailing arm, disconnected the brake line and wires from the trailing arms. Marked the bolt locations.
To remove the old bushings I drilled all around the bushing then used a gear puller to push it out. This took some effort I also had to use a chisel to get the remaining part of the bushing out.
Coated everything with Anti-Seize and used a couple plumbing floor plates to pull the new bushings in-place.
All in all not too bad of a DIY job, not sure how many hours the dealer would have charged for the job, my guess is around 3 - 4.
New TCKlines DA should be arriving tomorrow or Tuesday so that's next on the plate, then when that's over off for alignment and corner balance to go along with the new square setup.
2010 Dinan M6 Coupe--2006 Z4MC--1994 E36/M3 Track Prepped
BMWCCA #442445
YouTube Channel: http://www.youtube.com/user/Randy23185
RandysV10 is offline
      04-08-2012, 10:19 PM   #2
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Nice I decided to stick with oem and get the Vorshlag limiters. I'll end up using thy breaker bar method when pulling out the bushings...
Oh yea remember corner balance first, then alignment! =P
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
      04-09-2012, 05:39 AM   #3
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
I thought you were at VIR this weekend? Mike and Beth were there. Beth needed a new clutch before she went..
Shipkiller is offline   United_States
      04-09-2012, 06:59 AM   #4
RandysV10
MPOWERD
RandysV10's Avatar
Drives: 2010 M6
2006 Z4M  [0.00]
2010 BMW M6  [0.00]
Ouch, also seen someone kissed a tire wall Sat morning. I decided to not schedule anything for April and get some modes done.
So far got the new RTAB's, new Apex Arc-8's with some new Hankook RS-3 265/35 squared, Wheel Studs, Speed Bleeders and should be receiving today or tomorrow new TCKline DA Coilovers for installing this week. I'll probably run down to VIR on Saturday to watch some of the Club racing going on. If you have time and interested you wanna check it out?
BMWCCA #442445
RandysV10 is offline   Reply With Quote
      04-09-2012, 10:24 AM   #5
Shipkiller
Shipkiller's Avatar
That was Tods race preped 280Z. He banged out the fenders and had it back on the track that day. Beth kept sending me txt msgs all day.. Tod owns Tidewater Z.
I would like that but I am flying to San Diego on sunday so my Saturday is booked.
Reply
Forum Jump
