      03-30-2012, 04:43 PM   #1
trackhobo
BMdub Lover
trackhobo's Avatar
Drives: 2008 BMW 135i Coupe
Angry 05 3.0i Convertible Problem (again)
So I started a thread about a week ago about the part number for the hydraulic motor for the soft top. I read someone's article about how to manually put an automatic soft top down in the stow position, as mine is stuck up. When I press my convertible 'down' button, the latches connecting the top to the front of the vehicle disconnect, but the top does not go down. I found the red latch in the trunk that, if pulled out and rotated 90 degrees so it stays out, allows the hydraulic fluid to move freely through the motor. When I pulled it out, the top would still not go down. By go down, I mean with two people pulling on it and one person pushing up while inside the car. The hydraulic fluid will not move through the lines! How can I fix this? PLEASE HELP ME IM SO DESPERATE
      04-01-2012, 03:30 AM   #2
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
You should hear it release when you pull it.. Then you rotate 90 degrees.. I hope that the release is not broken too..:thumb down
      04-01-2012, 02:20 PM   #3
dreamingat30fps
Drives: 2014 335i, 2016 F150 Platinum
Weird the process you described is exactly how I have mine to put up and down manually without issue.
      04-01-2012, 04:44 PM   #4
sam04
Drives: 2004 m3
I just had to help fix one at an upholstery shop last week and we could manually get the top down with ease, it's very strange yours won't budge.
93401 auto detailing
san luis obispo car detailing
auto detailing arroyo grande
atascadero car detailing
car detailing san luis obispo
car detail in san luis obispo
morro bay auto detailing
http://www.sloresource.com/item.php?...+Spa&list=3532
http://www.manta.com/c/mvtj3jr/
http://www.sloresource.com/item.php?list=3532
http://www.local.com/business/detail...spa-115796545/
http://www.superpages.com/bp/San-Lui...2351156387.htm
http://www.facebook.com/CentralCoastAutoSpa
      04-08-2012, 04:35 PM   #5
trackhobo
BMdub Lover
trackhobo's Avatar
I know right? I'm afraid either the release is broken or the lines have seized. I took it to BMW and they said it was the motor but they never tried to move the top down. The weirdest thing is about three months ago I was able to take it down and back up with ease. Since then I can't do it, even with three guys pulling on the top. UGH.
      04-08-2012, 09:02 PM   #6
RecycledTeen
RecycledTeen's Avatar
Drives: Looking for E85
Read up on the motor fix and the associated components. Sounds to me like either your "bowden cable", the one your red pull handle is attached to, is too loose and when you pull it out (90 degree "locking position) it is unable to compress the ball check valve on the motor/hydraulic pump end that it pushes on, OR the check valve itself is "frozen", which could mean it's corroded due to too much water where it's stowed.
There's a plastic tension cable adjustment along the driver's rear left side that you could try to adjust (make it tighter) to see if it's the cable. (You'll have to pull out your rear trunk "shelf" to get to it).
Or, next best thing is to pull top and see if it's your motor (if the ball check valve froze you probably have other issues waiting to happen with that unit).
Not an expert by any means, just offering my 2 cents here having tore into the system recently.
Tags
convertible, hydraulic, motor, top
