03-23-2012, 01:41 PM | #1 |
Rep 296
Anyone for a 5lb car battery?
So braile batteries are good don't get me wrong but there is another option to drop almost 15 more pounds from your lightweight battery!!!
http://www.circletracksupply.com/Lit...-with-BMS.html $630 dollars is alot of money for a battery I will give you that!!! But if you are crfine or similar every pound counts! If you went from a conventional battery to this you are saving almost 45#'s from the get go! What are your thoughts on this? |
03-23-2012, 03:40 PM | #2 |
Rep 1,663
one love mentioned using a Lithium Pro battery in this thread and having no issues.
For me personally, I do want to get one of these at some point (and fabricate new enclosure/bracket so I can regain trunk space ). But I won't do it until I can lighten the front of the car by an equal amount to maintain the perfect 50/50 weight balance. Maybe a lightweight hood, since there's not many options for losing weight at the front.
03-23-2012, 08:07 PM | #4 | |
Rep 11,669
03-23-2012, 09:25 PM | #5 | |
Rep 879
03-23-2012, 10:51 PM | #6 |
enthusiast
48
Rep 1,695
I was incorrect. $120. 15 lbs. Odyssey PC 680
This is the battery that we use at the track. Not good for daily driving. They also make other sizes if you want more amperage. I do not know how they work with the z4m, since there are supposedly issues with not having stock batteries. http://www.odysseybatteries.com/battery/pc680.htm Last edited by seank; 03-23-2012 at 11:00 PM.. |
03-23-2012, 11:56 PM | #7 | |
instagram 997turbotom
286
Rep 7,377
03-24-2012, 12:19 AM | #8 | |
Rep 1,663
Pound per dollar it's not a bad mod: - Battery = -40 lbs. ~ $630 = $15.75 per lb - Seats = -90 lbs for both (recaro pole position). ~ $2k = $22 per lb - Hood = - 10 lbs ~ $4k = $400 per lb - Removing entire nav/radio = -45.6 lbs (just for reference) Other than that, don't know where else one could lose weight easily. Removing the entire bulkhead (per crfine's thread) only nets about -10 lbs if you put a cage in. I'm going to do more aggressive diff, then maybe seats/wheels before battery. I also figure if you wait long enough lithium battery prices will continue to go down.
03-24-2012, 01:29 AM | #9 |
Rep 855
Why run a battery at the track at all once you start the car the alternator will take care of it
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
03-24-2012, 08:16 AM | #10 | |
Rep 879
You can remove your A/C system Or the sound deadening in the cabin... Or switch your HID for halogen... But seriously, a big brake kit and some 19/20lbs wheels will save some pounds that you will be able to notice while pushing the car. Unsprung weight! Also, I will most probably buy just one Recaro PP and remove the passenger seat for track days. |
03-24-2012, 01:01 PM | #11 |
286
Rep 7,377
how about if you spin out and stall?
03-24-2012, 04:00 PM | #12 | |
Rep 1,663
Running only one Recaro PP in the front would make you about 110 lbs lighter than stock! For wheels I really want some TE37s.
03-24-2012, 06:30 PM | #13 |
Rep 165
There is another battery out there that is worth checking out. This is exactly 1/2 the price and performs just as well, if not, better. Check out this Shorai battery
http://www.batterystuff.com/batterie...36l3-bs12.html I have used 2 of these, and am totally satisfied with both. My first one was in my now sold S2000, used it for around a year without any problems. After I sold that car I bought another one for my Z4M. It's been in my car for around 6 months now, & loving it! My car is a weekend/track car so it does not get driven daily. Even after sitting for 2-3 weeks without being driven, it always cranks as strong as stock every time. |
03-24-2012, 10:06 PM | #14 |
Rep 855
That was a joke lol. Although it would work unless you stall etc
2014 335i M Sport
