      03-20-2012, 05:15 PM   #1
trackhobo
BMdub Lover
trackhobo's Avatar
Drives: 2008 BMW 135i Coupe
Post Looking for part number?
I'm trying to find the part number for the hydraulic motor that moves the convertible top for a 2005 BMW Z4 3.0i. Any ideas for the number and where to find one? THANK YOU!
      03-20-2012, 05:23 PM   #2
v3.2mc
Not a New Member
v3.2mc's Avatar
the motor and hydraulic pump are sold as one unit. you will most likely need the harness as well...
pump: 54-34-7-193-448
harness: 54-34-7-122-951
depending on where you get the pump, it will be shipped with the hyraulic fluid. if it doesn't come with...
fluid: 54-34-0-394-395
GLW your repairs! and welcome to zpost!
      03-20-2012, 05:25 PM   #3
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
http://www.realoem.com/bmw/showparts...13&hg=54&fg=10
Hydro unit 1 05/2006 54347193448
Hope this helps..
http://getbmwparts.com/
I list them because that is where I have purchased various parts.. I am sure there are other places you can check...
      03-20-2012, 05:28 PM   #4
MHeavNC
MHeavNC's Avatar
http://www.trademotion.com/parts/ind...&siteid=214672
Here is the part at the website.. Read as much as you can before attempting to change out the motor.. I think that Shipkiller has a good DIY...
      03-20-2012, 05:29 PM   #5
trackhobo
BMdub Lover
trackhobo's Avatar
@v3.2mc, thank you, this is a great site. @MHeavNC, thanks for all your help, the sites are fantastic.
      03-20-2012, 06:50 PM   #6
DataStream18
Drives: 2004 ESS TS2 Z4R
Also after you have the part number http://www.ecstuning.com/ is a pretty cheap place to get parts too, there are others you just have to look.
Love is like a fart; if you have to force it, it's probably shit.
Tags
convertible, hydraulic, motor.
