      02-21-2011, 01:19 PM   #45
Fraser-Z4
Drives: Z4
Hi Guys,
I've currently got a UK '2.5i' N52 with 177bhp, this already has a three stage intake manifold as standard, however the UK '2.5si' with 214bhp (both cars are 2500cc) also has a three stage manifold with a different part number - 11617559526 vs 11617559525. I'm guessing the one fitted to my car is slightly more restrictive (it is the only engine components with a different part number between the two engines), so I'm swapping it for the manifold off the 'Si'.
I'm looking for a used one but does it matter what mileage car the manifold comes from - is it a part that may wear out with age/mileage? I'm guessing not as it's got no moving parts - I'll be using my own DISA actuators.
Cheers
      02-21-2011, 02:04 PM   #46
-c-
-c-'s Avatar
Drives: X5, Cooper S, Z4, i3,
well im geussing as long as you get the manifold of the 2.5SI and not the 3.0 you should be fine. Normally used manifolds already come with the disa motors so keep the others for spares, you will also need a tune taking advantage of the manifold so you will want to take it to a dyno someware and have a custom tune for your car so it more resembles the map of the SI vertion of your car. then you should get close to the numbers if not at the numbers of the SI.
dyno results show an increase of 10HP gain on the 3.0I with just the manifold swap and no dyno tuning.
      02-24-2011, 04:08 PM   #47
Drives: E85, E90, F25
not to take away from this mod, but i think some people really under estimate the engineering that went into these cars. yes, the 3 stage manifold swap gets you close but there are clearly other factors to consider, of which are not easy to get around. this thread here addresses one of the issues with the valvetronics:
http://www.e90post.com/forums/showthread.php?t=492995
but Gavin sums it up well when he says:
"without an actually recoding of the ECU to allow for a higher models specs (re VIN and code the DME and Tranny), only so much can be done within a tune itself."
      02-25-2011, 01:12 AM   #48
-c-
-c-'s Avatar
Craven is a great guy but unfortunately he's not correct about everything. and their is something I'm planning that will knock your socks off hopefully spring to summer ...also their is a way you can make your I think its an Si without even flashing the ecu .....wrap ones mind around that lol. found out how to do it a bot ago and its easier than you would think.
also you have to think of it like how Apple kept trying to keep people from jailbraking the iphone, the day the patch was released they hacked it. their is very few systems out their that can't be cracked and BMW systems though a pain are no different and in the hands of a skilled tuner its amazing what can happen.
also this all is relatively new, give it time. Shoot the mini when it came out people said it was impossible to hit 200hp now that's been blown away and people are chasing 300hp.
but again you'll see some very cool things coming soon.
You have to have an open mind.
      02-25-2011, 01:23 AM   #49
-c-
-c-'s Avatar
Plus I know their are a few Si owners who want this to fail as they don't like the idea of a bunch of I's running with their cars ....had a couple PM's from people who didn't like the idea and gave me a bunch of false info before I even did the mod. But as with everything....anything is possible given enufe time and patience....it may not be worth it for some but I like a challenge, hence the dual M exhaust on an I. I head that was somewhat not feasible either.
Hey I'm having fun and sharing my experiences with others nobody has to do it but the options are their.
Hugz.
      02-25-2011, 08:35 AM   #50
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
i like your mindset and originality
2007 TiAg ///MCoupe
      02-25-2011, 10:02 AM   #51
Hugz.
If you're implying that I was being a hater, that was not the intent of my post. I just wanted to give everyone the newest "update" on this mod seeing how it was the folks at e90 who originated the process.
      02-25-2011, 10:48 AM   #52
Drives: E86 Z4MC; E92 M3
Hugz.
That's what it's all about.
Nice work C.
      02-25-2011, 10:50 AM   #53
-c-
-c-'s Avatar
yea it sure is getting heated over their!!!!
either way, you have the people say it canít yet others say it can, itís just a big war over there, lol exciting.
naa Dubbedown I know your cool, just was pointing out that not everything one hears on the internet is necessarily true, Iím in the auto industry myself and have a friend that works in BMW design in Germany and things are not as complicated as it would seem.
everybody has different skill sets, and Iíve seen some amazing things that others can do that others say canít be done, hence why when people say this is beyond our skill level, I take it more as its beyond their skill level not mine, the people I work with everyday design these systems and itís their normal everyday job, but when you talk to the public itís like they look at you like rocket scientists.
One funny story is, BMW could not fix the stumble problem on their MINI cooper S platform, and a friend of mine broke BMW's code reworked the ECM programming and got rid of it. took it to the dealer and met with a rep, worked with BMW on the problem and BMW took the data, tested it and viola it worked and used his programming to fix the stumble. it helped in this matter he was a creditable engineer in a automotive software company. What Iím getting at is the world works in funny ways, and donít say it canít be done until everything has been exhausted. theirs a big difference in making a marketable software or item to sell, and if itís not within a price range its considered imposable to do. VS. just a one off that the person involved can achieve anything they deem is right for them, and spared no expense.
for instance making a kit or setup for dual exhaust on an I or Si would make no sense for a company and be considered non-doable because of the price and complexity, youíre better off buying an M, so you probably will find no body will jump in to make this a viable option unless you go it alone. but for me, I get the engine I want with the car I like and now I get the look I want. benefits to me is drivability, low maintenance engine, low insurance premiums and a beautiful car to cruise in.
again Iím not saying anybody is hating Iím just talking in generals.
      02-25-2011, 11:01 AM   #54
-c-
-c-'s Avatar
Nice work C.
Thanks Man!
Hey if I stopped every time someone told me the situation is not going to work or is imposable to achieve id never had achieved in life what I have.
itís about breaking the mold and going against the grain that gives me the energy to get up in the morning, probably why Iím a designer, I love to challenge myself and it give me a great sense of accomplishment when I can look back and say to myself "I did that" or look at my friend and say look what we accomplished together! itís quite gratifying from time to time.
      02-25-2011, 11:19 AM   #55
-c-
-c-'s Avatar
sorry for all the long posts,
but either way you slice it, this is an excellent mod that does gain you more HP and torque than most any other mod out there and its technically the cheapest.
and its STOCK! lol
$250 for a manifold with valve adjusters (used)
and 300 for base tune.
and the outcome is more HP than any exhaust or intake and is cheaper or at similar cost.
if anything this mod should be embraced as its the cheapest HP to dollar amount that can be had on any non M z4
      02-26-2011, 07:58 PM   #56
Fraser-Z4
Drives: Z4
The thing is though a couple of people have done the swap over on e90post and it's worked (budvlad & e90pilot I think) so I can't see why people are saying there are other limiting factors?
It's possible that the vin coding on the ECU limits the valvetronic adjustment but I don't think there's any evidence of this. I know a few of the UK tuners are able to freely adjust the valvetronic lift.
      03-10-2011, 12:20 AM   #57
kirkpart2
kirkpart2's Avatar
Drives: 2006 BMW Z4 3.0i
Success story .... ..... I don't know nearly as much as most people here but at 20 bucks a HP (which I can truly feel on the road) i think it was worth it for me
http://www.zpost.com/forums/showthread.php?t=499389
BMW Performance | SuperSprint | 17" M3 CSL Replica's | Active Autowerke | Stop Tech | RPI | 3.0I to 3.0SI Conversion
      08-15-2011, 12:10 AM   #58
-c-
-c-'s Avatar
hey guys just updated the DIY with some new info from AirOpsMgr, he just got done with the install and gave some tips!
a big thanks goes out to him.
also stay tuned to the ecu update coming, this should put us at or above SI hp as it will be able to truly recode the ecu using true BMW SI programming on our I ecu's so this will not be a "tuned I software" but a true recode with stock OEM SI tune or tuned SI map running on the I ECU...
very exciting!
      08-15-2011, 12:47 AM   #59
AirOpsMgr
AirOpsMgr's Avatar
Drives: 2006 Z4 3.0i
very exciting!
Well, the real thanks goes to -C- for the DIY to start with; following the instructions, I had the old manifold out in a few hours (it took a while as I was double and triple checking everything that I disconnected, labeled everything, etc).
The manifold I got (from an 06' 530i) came with lots of extra parts still attached, so I had to remove the things I didn't need and transfer a few things over from my manifold, but didn't take long.
The installation of the new one is pretty straight forward, especially after learning where everythings goes and how it connects; I'd say it was about an hour to put it back together and another 30 mins to turn the engine on, check all the connections, etc. I was pleased to see no warning lights, had no odd or stranges noises ...... the engine actually sounds like its running smoother ..... perhaps a placebo effect, but thats my story and I'm sticking to it!
Once on the road, it was a noticeable improvement; my first gear pegged 7K more quickly than before and could feel the difference in how she pulled harder through the gears (I also have the K&N drop in high-flow filter which helps a bit as well).
I am very eager to get the SI tuned ECU flash, and by the looks of it, -C- is on the right track and it should be coming around pretty soon. I think he is still looking for interested parties for a group buy.......
Brgds/Greg
      08-18-2011, 10:11 PM   #60
AirOpsMgr
AirOpsMgr's Avatar
Here are the Dyno figures after swapping out the original manifold for the 3 stage.
My setup is a 2006 3.0i (N52), 3 stage intake manifold, K&N high-flow drop in filter with air-box charcoal filter delete (No ECU tuning yet) - Best run was 191.0 hp / 176.0 ft/Ls torque (add 20% loss according to the Dyno guy) and that puts me at 229.2 HP
Name:  2006 Z4 3.0i dyno.jpg
      08-20-2011, 01:39 AM   #61
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
Nice results....Do you also have the updated cylinder head? I noticed my car seems to have more torque and HP since I have had mine replaced.. I can't wait to install the three stage... Hopefully this fall...
      08-20-2011, 09:53 AM   #62
AirOpsMgr
AirOpsMgr's Avatar
No, unfortunately I bought mine out of warranty and "as-is", previous owner never had the head replaced with the updated version. I only get ticking if I let it sit for a few days, so I don't think I'll be dropping the cash to replace it anytime soon.
I've only spent $350 to get HP gains that you see (would have only been $250 if I would have shopped for a better deal on the intake manifold, but I was in a rush), not sure how much more HP I would get with the updated head, but that is an interesting point!
      09-15-2011, 12:02 AM   #63
MHeavNC
MHeavNC's Avatar
Noticed this list on the 3 Series forum... Do I need to get the new screws and vent hose??
11617559523 Intake Manifold
11617559530 Vent Hose
11617579114 Adjustor Unit
11617560538 Adjustor Unit 2
11617547242 Gasket set
11617535849 x5 Screw 50x20
11617535850 x2 Screw 50x35
11617535851 x1 Screw 50x66
Also, for those who have made the swap and still running the stock tune,...... how is it running??? Does it seem that your ECU is slowly adapting,..... somewhat??
      09-19-2011, 11:28 PM   #64
-c-
-c-'s Avatar
Hey their sorry haven't been on much as of late been busy .... I used everything my car had their was no extra parts needed .... The vent hose is if you break yours.
As far as stock tune its driving just fine with the three stage and as you will read from others have seen nothing but improvements.
I am however sending an SI ecu with my I ecu to have it converted over whitch will land me proper si HP and performance even an si tune will yeild better performance from the stock si tuning so in theory I should finally meet my goal of having the same HP if not more than a stock si ..... Combine that with the better rear end gear ratio in the I and better yet in the auto I should pull very nicely indeed...ill keep you posted.
      10-18-2011, 04:41 AM   #65
Stilweezy
Not new, not old
Drives: 2003 Z4 3.0i Sterling Gray
so this mod is only for 06-08 3.0i, not for 03 3.0i since we have a different engine?
      10-18-2011, 10:16 PM   #66
-c-
-c-'s Avatar
yes only for the N52 based engines.
