06-06-2012, 10:40 PM | #1 |
Rep 615
Routine maintenance gone wrong!
This just goes to show that even the easiest of DIY's can go bad sometimes. I decided that with about 30k miles, I'd go ahead and change the vanos filter in my car. Seemed simple enough. After all, I've changed shocks/springs and can do my brake jobs in my sleep.
I watched the DIY video on ECS tuning's site and it seemed like about a 3-minute procedure. Took off the old filter using pliars, then used my hook shaped picks to get out the old O-rings. Then when I went to replace the new O-rings, I noticed that in the space where the smaller of the two O-rings goes, there is a little plastic ring that butts up against the O-ring and this plastic ring was damaged when I removed the old one (see attached link for picture of this). It was cut such that it no longer made a full circle. Why do they even have this plastic ring here. The bad news is that the plastic ring has no part number and cannot be replaced. Buying a new vanos assembly is about $175. Do I drive the car without the plastic ring or bite the bullet and get a new vanos assembly?
06-06-2012, 10:44 PM | #2 |
707
This is probably a stupid idea, but what if you ran buy an auto parts store to see if they carried a little plastic ring the same size?
Sorry man, this really stinks! I've had similar crummy things happen on "easy DIYs" and it's really frustrating and unsettling. On the other hand, you have to wonder whether a shop might just say "WTF" and replace it without the plastic piece or reuse the damaged one. At least with the DIY, you know there's a problem, and you won't just ignore it. |
06-07-2012, 01:57 AM | #4 |
707
Okay, good news, it looks like the "broken" white plastic ring is supposed to be that way.
Does it look like this? Looks like the plastic simply acts as a spacer, and is supposed to have a "break" in it. If yours looks like this, then . More info: take a look at this thread, especially posts 16 and 17; and this thread, posts 52 and 53. |
06-07-2012, 08:00 AM | #6 | |
Rep 615
06-07-2012, 08:23 AM | #8 | |
Rep 1,772
Drives: 2007 Z4M Coupe
If it was a 1500 dollar piece, whole different ball game but we are talking about 2-3 fill ups at the tank
06-07-2012, 09:21 AM | #9 |
Rep 280
It's called a backup ring, it's used in many hydraulic applications. It prevents the oring from extruding into the groove. They are split, but do need to make a full ring when compressed and installed in the port - just like piston rings.
So - do not use your damaged one. Buy the new part and consider it a fairly inexpensive lesson in mechanics!! |
06-07-2012, 12:01 PM | #11 | |
Rep 615
06-07-2012, 12:56 PM | #12 | |
Mark Z4
Rep 2
Filter
06-07-2012, 02:33 PM | #13 |
Rep 615
No. See post 11.
06-07-2012, 03:46 PM | #14 |
707
Did the ECS instructions mention anything about the backup ring or offer to supply one?
Seems to me that:
06-07-2012, 07:43 PM | #15 | |
Rep 615
Of course this is not a dealer stocked part and it will be several days before my car is back on the road now. Good thing I still have my good ole 530i as a backup car.
06-07-2012, 11:29 PM | #16 | |
Rep 421
I removed the end to half circle. Maybe save the white ring. Part 83 30 0 490 533 $15.11 |
06-14-2012, 10:06 PM | #17 |
Rep 615
My replacement part finally came in today so after 8 days of not being able to drive the car, it was nice to have her back. I studied the new part closely to look at the white plastic ring. It fit quite loosely and it clearly has a cut in it so that it can be installed and/or removed. However, based on the condition of my filter after 29k miles, I doubt I will ever remove the valve again. I change my oil every 5-7k miles and the filter had no residue or blockage at all on it. As long as you don't use the full oil change intervals as set by BMW, I wouldn't worry about this filter at all.
06-16-2012, 04:15 AM | #18 |
Rep 313
My car gets oil changed about every 7500 or less since I don't drive so much that the annual kicks in... so I guess I'll skip on the vanos filter change for a little longer... I'm at about 32K now... thanks for posting.
