06-30-2020, 04:46 PM | #1 |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
Coilovers Ordered; Requesting Advice
I finally pulled the trigger on a set of coilovers, something I wish I had done a while back, but better late then never.
I plan on replacing the rear shock mounts with an upgraded set from ECS that come with reinforcement plates, as well as new OEM front strut mounts. Is there anything else related to the install that I should consider replacing that would be be helpful or make the install easier? Cheers!
Evolve CF CSL Airbox /// SGT Headers /// DKF Resonated S1 /// RPI Mufflers /// Underdrive Pulleys /// Alpha-N Tune Mstache /// CF Side Extensions /// Skyer CF Rear Spoiler /// CF Engine Cover /// Strong-Strut Braces H&R Coilovers /// MRR GF7 Wheels /// PS4S /// Remote Start /// Rennline Pedals |
06-30-2020, 05:34 PM | #2 |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
These are the items I'm planning on replacing; anything you think would be unnecessary? Anything I'm overlooking?
07-10-2020, 12:24 AM | #3 | |
Rep 104
07-10-2020, 12:54 AM | #4 |
707
Looks good if you're not going in for front camber plates. I just installed a set of Bilstein B6s and the list was essentially the same. The only thing I added was an E36 bolt/camber washer kit (15 bucks) which lets you get -.1.5 —2.5 up front without camber plates.
You'll lose a bit of clearance between strut and wheel/tire, but unless you're running 255s or 265s up front it's unlikely you'll experience rubbing on the springs, strut, or spring perches. And it's easy enough to check before torquing everything to spec. Running very little toe-in (or zero toe) sharpens the turn in and reduces understeer without eating tires. Not for everyone but I like it. |
07-10-2020, 07:28 AM | #5 | |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
My stock shocks/springs were just toast and needed replaced, anyway, so I figure might well get the H&R coilovers since they barely cost more than replacing with all OEM parts, anyway.
07-10-2020, 10:22 AM | #6 |
AKA No_Dominion
174
Rep 158
Drives: 2007 Z4M
Disregard Finnegan I tracked them down on ECS. Just ordered the bolts along with all the replacement pads/mounds/perches/etc. Coilovers finally shipped, so hopefully I’ll be able to get them out on here in about two weeks!
Thanks for all the input everyone, I’m definitely looking forward to having a refreshed suspension, and a bit of drop will of course be a nice bonus.
Finnegan707.00 |
