      03-14-2018, 09:45 AM   #1
Waoudi
Waoudi's Avatar
Drives: '17 X5 MSport, '16 M3 ZCP
What is this part?
Hi,
While looking "under the hood" after getting a check engine light i saw this flap open and I don't know if it should be open or it's stuck against another part.
Thanks in advance
Still trying to figure out how to upload images so use link below please.
https://ibb.co/gwienx
      03-14-2018, 10:01 AM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
That's just a water drain for the windshield cowl. It is normally closed. Maybe see if there is some debris preventing it from shutting all the way.
Salty
Waoudi23.00
mainsoda171.50
      03-14-2018, 10:05 AM   #3
Waoudi
Waoudi's Avatar
Thanks! Any chance that could cause a check engine light? I should be receiving the Carly OBD today (I have the VGate for the X5 and it doesn't work to get the codes so now i own 2).
      03-14-2018, 10:11 AM   #4
SaltyNC
SaltyNC's Avatar
370
Nope. Must be something else.
