10-09-2016, 06:02 PM | #1 |
Rep 130
Top 10 Wish List
Likely this has been posted previously but now buried somewhere deep in the thread logs. If so, I apologize in advance.
Top 10 wish list! If you had a $10k-$12k budget, what would be your first most highest priority mods to your z4M supercharged coupe? I'm looking at: ESS s/c (used) headers/catless full exhaust with Flowmaster 5-chamber mufflers (I'm too old for loud rappy cars). Custom tune (no canned/OTC tunes with s/c & headers) Where would YOU go from here? (I know it's always easier to spend somebody else' money). Thanks for your sincere, serious input. |
10-09-2016, 08:07 PM | #2 |
Rep 1,443
Those are good mods but a lot of people start off with suspension, wheels and tires. More fun for the $ initially I think.
RedOctober32.50 |
10-10-2016, 08:16 AM | #3 |
Rep 405
Moton coilovers/camber plates with professional set up/balancing
Stop tech bbk Welded in rear cage Custom aero kit If another 15k was available Supercharger Carbon fiber body panels, roof, hatch Rear Overfenders for bigger tires |
angelr188.50 RedOctober32.50 |
10-11-2016, 05:07 PM | #4 | |
Rep 130
Personally, wheels/tires aren't in my top 5 of "must do" mods. But thankfully there are some great deals on used sets, so it's an option. |
10-11-2016, 05:10 PM | #5 | |
Rep 130
Why coilovers/camber plates? Is the z4m that lacking, especially up front? Same question with the bbk's. For me (and maybe I should have stated this earlier), my z4m is not a track car. And a bbk would easily consume half my 10k budget. I'm just asking. Your wisdom would be appreciated. As for a cage, is there another way to tighten up the rear like hd sway bar/bushings, etc? Thanks, Red |
10-11-2016, 05:33 PM | #6 |
11120
Rep 4,930
TBH I wouldnt buy a superchargerkit used unless you know what you're doing.
If you buy used you still need the tune and foremost: you need support.
10-11-2016, 06:17 PM | #7 |
Get off my lawn
938
Rep 1,162
If a SC coupe was really my intent a higher budget would be my first priority. More power is going to accentuate the need for better cooling, braking, tuning etc and quality does not come cheap.
10-11-2016, 10:48 PM | #8 |
Rep 1,443
I mainly meant coilovers or shocks and springs if you choose to go that route. Camber plates, upgraded bushings and swaybars are also beneficial. I wouldn't consider big brake kits one of the more common mods that people here do since our stock brakes are more than capable of handling what most of us throw at them but they certainly have their place and more than a few here have done a conversion. Due to the stiffness of our chassis I think shock tower braces are generally considered to be more for looks than function. That said, I do have one.
RedOctober32.50 |
10-12-2016, 07:34 AM | #9 |
1624
Rep 4,296
10k? Csl intake, suspension and Aero. oh and save a K or so for bearings. And that's if the car has been refreshed before, if it's got 50k plus on it, with this age, id be spending that 10k on refurbishing the whole underside of the car.
10-12-2016, 07:50 AM | #10 | |
Rep 130
Car has 15k on it. Why bearings? Mains or rod? I wasn't aware of any issues. |
10-12-2016, 08:51 AM | #12 |
Rep 1,443
We tend to keep things polite and nonpolitical around here. There are other forums for those comments if you're interested.
10-12-2016, 05:29 PM | #14 |
Rep 130
10-13-2016, 07:13 AM | #16 |
Rep 130
10-13-2016, 09:39 AM | #17 |
Rep 2,882
Rod bearings appeared to be an issue on some of these S54, so most of us monitor wears doing oil analysis. Recommend that you do the same on every oil change to keep an eye on it.
RedOctober32.50 |
10-13-2016, 04:30 PM | #18 |
Rep 2,782
The only thing you need with a supercharger are wider wheels and stickier tires. Without upgrading, you won't be able to put the power down.
I'd go for catless headers too, to reduce backpressure and heat. Suspension and braking mods are nice but not necessary, unless you intend to track the car.
RedOctober32.50 wdb4762.50 |
