08-20-2022, 05:16 PM | #134 |
Rep 364
08-20-2022, 08:07 PM | #136 |
Rep 364
Does your CSL intake have extra bracing in that part?
The CSL intake has pretty much no restriction after the filter element, so maybe the OE airbox and MAF create more of a restriction and more vacuum in the plenum? |
08-21-2022, 07:23 AM | #137 | |
Rep 352
Problem is finding a good intake for a Z3M these days isn't easy. |
08-26-2022, 08:02 PM | #138 |
Rep 364
Okay, so I have a couple of questions to ask Karbonius:
- can the plenum be strengthened so it doesn't flex so much? - which rubber boots were used in the design (my understanding is that Z4Ms and post-2004 E46 M3s have one type of boot (part number 11617835861) and pre-2004 M3s and M3 CSLs have another kind (part number 11612466477) and they're not interchangeable. This also means the OE clips on the plenum side are different - Z4M is 11617835320 and pre-2004 M3/CLS is 11617830306) Before I go back to Karbonius I want to check if anyone else has questions or comments? E86Z4MC grannyknot AK72 86Zed wdb drivetolive pwnsweet alfadog TurboDream17 zed_fan sgrg GuggagZ4M RvsBmw Barryb97 ZeD4Mr Mtxzptlk Kuky Jdmaflac krohn27 Polarbert flipjohannon |
GuggagZ4M22.00 |
08-27-2022, 05:05 AM | #140 |
Rep 364
08-28-2022, 09:44 PM | #141 | |
Rep 12
08-29-2022, 04:39 AM | #142 | |
Rep 41
Thanks for asking. |
08-29-2022, 06:04 AM | #143 | |
Rep 364
RvsBmw - Not to put words in their mouth, but I would imagine they could be willing if there was enough interest. Getting enough interest would mean going down the same path as we have for plenum. I'll float the idea with Karbonius. |
08-30-2022, 05:53 AM | #145 | |
Rep 364
They have come back with responses to my other questions: Q. There appears to be quite a lot of flex in the top of the plenum. People have expressed concern that this could result in the unit failing over time, probably where the two parts are bonded together. Is there a way to strengthen the top? Or do you think this isn't needed? A. Yes, a lot of flex on the top, this is because this unit was made without the inner pilar reinforcement, we are installing a inner reinforcement ( like the ones we are using in the CSL airbox) and we will test again, I hope not to loose too much sound!! Anyway ,I´m not worried about the union between 2 pieces, I´m sure will not fail on this area, we are using a very good glue, it support a lot of cicles of flexion and traction Q. Is it possible to order the plenum without any logo or writing on the top? A. Yes , no problem, we could send it with the Mpower sticker separately ( not glued under the varnish) I also asked about the rubber coupling and they advised that their plenum is designed to work with part number 11617830265. This is part from the CSL and pre-2004 M3. https://www.realoem.com/bmw/enUS/par...&q=11617830265 Can anyone confirm if Z4 and post-2004 M3 rubber couplings work with the CSL airbox? I have never read that they DON'T, but would like to confirm as the rubber boots are quite expensive. |
08-30-2022, 09:37 PM | #146 | |
1624
Rep 4,296
That's actually a really good video showing that the TB want more air than the OEM intake can provide.. Very interesting. I wouldent worry about the flex too much, KB make excellent products and they know the materials they work with, unlike some other rubbish companies.. yeah I am looking at you Evolve. Very cool project, and lovely sound. Nice job so far Mban. Last edited by Vanne; 08-31-2022 at 10:55 AM.. |
wdb4773.00 |
08-31-2022, 06:35 AM | #147 |
Rep 364
Thanks, Vanne!
Karbonius said that they did think about making an elbow and airbox when they were testing plenum. Apparently this could 'maybe' be the next step but will be a few months before they could give it any attention. |
08-31-2022, 10:19 AM | #148 |
Rep 978
Yes, I have their CSL box and those pre-LCI E46 M3 boots fit our cars, the difference is on the box side, not the throttle bodies. We are good. (As long as you get the old style boots)
09-02-2022, 08:24 PM | #149 |
Rep 364
Karbonius have added a 'pillar' to the plenum to reduce the flex and re-tested. Volume appears to be unaffected. Possibly there's a slight change in tone? Video below.
To plan a production run, Karbonius are asking for people to indicate if they intend to buy one. I'll start a list in the next post. Don't forget that Z4 people and post-10/2004 M3s will need to buy the old rubber couplings and matching clips for the plenum side (parts 3 and 4 here https://www.realoem.com/bmw/enUS/sho...diagId=11_3517. Or, you can buy the Turner silicone coupling kit, which is quite a bit cheaper than buying new OE parts. Karbonius plenum with extra reinforcing: https://youtube.com/shorts/-6nf6_zrNxY?feature=share Karbonius plenum without reinforcing: https://youtube.com/shorts/NtCRPz1705A?feature=share |
09-02-2022, 08:25 PM | #150 |
Rep 364
List of people committed to buying a plenum:
1. MBan 2. Barryb97 3. Polarbert 4. Kuky 5. maupineda 6. 86Zed 7. R717 8. survivalist 9. alfadog 10. 9kracing 11. JuicyM3 12. cliptheapex 13. gregl342 14. henderson_louie 15. theBMWaddict 16. Jdmaflac 17. Nicholas T (FB) 18. TeddybearCup 19. Kevin T (FB) 20. GuggagZ4M 21. jrgatfh 22. TurboDream17 23. Ddot12 24. LateBraking 25. hopz121 26. flipjohannon 27. PayamSFU 28. Mark A (FB) 29. Plunky 30. HBC (pending testing to make sure no power loss) 31. Mousitch Last edited by MBan; 11-08-2022 at 05:23 AM.. Reason: Update list |
GuggagZ4M22.00 |
09-03-2022, 05:06 PM | #154 |
Rep 12
I’ll need to verify which year motor was swapped into my chassis but for the aftermarket couplers, we are referring to these correct? Great alternative to the OEMs for the price.
https://www.turnermotorsport.com/p-5...t-with-clamps/ |
