10-26-2012, 06:02 AM | #111 | |
Rep 5,329
1) nothing but its position isnt ideal!! im an attention to detial freak!!! 2) The intercooler pipes snake in and out of the bumper sections and the rad shrouds ect ect they are abit of a bitch to fit but nothing crazy, the one is a bastardm the long one from the outlet, on my car we simply couldnt get it right so we removed it and cut it, added a section and re powder coated it.... before it would blow off and make a huge PPPOOOPP!!! lol when i get home ill get some pics.
10-28-2012, 04:31 AM | #112 |
Rep 5,329
so jad.... still going with this decision.... ??? looks like the HPF you wanted actually really may be coming through!!!! ???!!!!
10-28-2012, 11:22 AM | #114 |
Rep 5,329
i dont think HPF has ever had tune issues??? or hardware issues??? im pretty certain it was getting the ECU to work, they are going to use the new AEM infinity setup now :-)
10-28-2012, 11:30 AM | #115 | |
instagram 997turbotom
286
Rep 7,377
1. I didn't clock my supercharger and I'm fine. Slightly rotating it WOULD make it easier to access to screws to check the supercharger oil level 2. The pipes will not grab enough silicone connector between them if the rest of the kit isn't sitting properly. The hardest part for me was the main silicone connector coming down from the intake manifold. The supplied one was too short, so I bought a longer aftermarket one. I later realized that it was too short because of the way I positioned the intake manifold 3. The intake manifold, once you have it loosely connected, should be angled down towards the ground as much as possible while still retaining a good connection at the throttle bodies. Otherwise the blow off valve will rub against the hood, and you'll have problem #2 4. Invest in T-bolt clamps. I don't remember my sizes, but just replace the ones ESS provides. Don't overtighen T-bolt clamps, theyre very strong and can break pipework 5. The oil cooler uses STOCK o-rings. never forget. Get extras as beedup said 6. The power steering pump will be relocated during the install, be advised that its lines will be under high tension for it to placed where ESS wants it. If you can (I didn't), replace the lines with longer ones. 7. One of the lower intercooler pipes has a threaded hole thats used to grab onto a bracket and gets secured to the body of the car. I was given wrong size and shape brackets, but was able to easily manufacture one with a aluminium 1" wide bracket 8. Boost gauges are great and used often to verify that you're not getting a boost leak anywhere. They're worthless if they don't have a peak boost recall function, unless they're mounted up high near your eyes. Believe me, you don't want to be watching the boost gauge while going full throttle in 2nd gear to redline 9. Coils may blow upon initial startup. Mine did. I replaced all 6 with ones from Bavauto for about $280 10. Dynograph the car BEFORE and THEN after the install. Otherwise you will only have half of the story. Many dynos show wildly different numbers. At least you'll be able to know what your local dyno's drivetrain loss is for 333hp, and then use that info to get an accurate crank hp number after install 11. The fancy shaped plastic piping coming from the supercharger will rub on the hood, and create a shiny little wear area on the pipe. I didn't touch this, but some people found a way to increase clearance. Its only touching it by 3mm or so 12. Be there for the install. Learn it. If anything goes wrong, you should be the expert on your own car.
10-28-2012, 12:46 PM | #116 |
Rep 912
Thank you roffle, you guys are the best, i sure hope i will get ut right on the first time after all your remarks. Your feedback is so appreciated
Ama get some s54 boost yall |
10-28-2012, 02:51 PM | #117 |
Rep 5,329
note on toms point 11... it WILL NOT touch the hood if instaled in the way i noted on my notes... trust me :-) theirs a certain position and it wont touch
10-29-2012, 12:27 PM | #118 |
Rep 912
Guys, can you please tell me which clamps should i buy? how many and what size?
and from where if you have that info? Should I also buy coils and sparks all together? Should i buy the fuel filter and change that before installation? I have 75K KM, that's like 45K miles. |
10-29-2012, 05:54 PM | #119 |
286
Rep 7,377
here's some info on the advantage of t-bolt clamps. Sorry, you'd have to get a list of clamp sizes from ESS, I don't remember what I got
Buy new oem spark plugs Bav auto coils are their part # 5004 6 on http://www.bavauto.com/shop.asp I would do the first startup on the old coils and plugs, and then swap in a day or 2. I don't know what it is about the very first startup that kills oem coils
10-30-2012, 02:20 AM | #122 |
Rep 912
I'd also like to know about the part number for the O-rings for the oil cooler, if you guys don't mind.
Is it 17 22 2 245 358? How many i want to buy? 2? |
10-30-2012, 03:09 AM | #123 |
Rep 5,329
i brought 4 just in case.... but 2 is all you need :-)
11-02-2012, 01:41 AM | #125 |
Rep 912
last week some guy came with an old 2001 M3 to buy a KW V3 upgrade and luckily there was one in store, so we had a little chat and I asked him about his car and if he was happy with it. He had an old Rotrex build AA kit stage 1.
After some negotiation, I drove his car for a bit just for fun, I had the shock of my life. @3k rpm cruising in 3rd gear I decide to plant it, the amount of power there was when I put my foot down was simply ridiculous, i couldn't believe that his car was 425 HP only. Compared to the dinan of my friend , this car absolutely destroys it, I don't know how would the ESS behaves in this case knowing that the dinan was pushing boost on a vortech and making 507 HP on the dyno :s I just stopped understanding this stuff, I don't get how these supercharges develop boost :/ someone with technical data, please chime in on compressor maps. Last edited by tikamak; 11-03-2012 at 03:59 AM.. |
11-03-2012, 03:37 AM | #126 |
Rep 5,329
VT2-500 with tial BOV sounds great!!!
their a special greddy to tial converter flange... this bolts right up... i think it sounds great and adds abit of drama... i LIKE!! Shame, i love the idea of recirculating boost and shoving it back into the intake...... their has to be benefits to this way, but its boring and makes no noise :-(
11-03-2012, 05:58 AM | #128 |
Rep 5,329
the one supplied with Ess is a very effective unit..... it makes some different noises but defo doesnt make the usual BOV noises as its a re-circulating unit.... so its diverting back into the intake, this should technically improve throttle response, instead of dumping the air to atmos its dumped upstream of the blower, so its been re-used....
the tial sounds sick though!!
11-04-2012, 04:40 AM | #129 |
Rep 912
I didn't understand something here, the small tube coming from the ESS BOV is going into the supercharger again.
How does this improve throttle response? you mean it will have the supercharger working less to suck the intake air and develop the same amount of boost? |
11-04-2012, 07:00 AM | #130 | |
Rep 5,329
11-04-2012, 07:05 AM | #131 |
Rep 5,329
take a look, horrible example but it'll do
