06-22-2010, 12:49 PM | #23 |
Rep 1,603
Drives: Imola Red Z4MC
nice review! Sounds like its great to drive!
///M - Some Mods 'N Stuff
06-22-2010, 07:24 PM | #24 |
Rep 1,546
LUCKY!!! I'm hoping to get myself on the track and get used to the stock feel and see what i want to do with it before i throw a bunch of money at this baby. CANNOT wait for the dynos though! congrats!!
06-23-2010, 02:13 AM | #26 |
Z4MC Sapphire Black
46
Rep 177
Oh that's easy, just go to thread tools.. click 'Subscribe to Thread'...
make sure you got instant email notifications.
06-23-2010, 07:27 AM | #27 |
Rep 2,782
Thanks for the review. How much did the install run you? I'm trying to estimate an out an out-the-door price.
06-23-2010, 10:28 AM | #29 | |||
Rep 2,747
Thanks
Thanks, it is a blast to drive. Quote:
Destroy your modem. Quote:
It will vary depending on the shop. The local install price was quoted @ $749.00 and I was able to get it done for slightly less. I would contact your local ESS authorized shop to find out. Also, there was no tax on the install because it was all labor. This should give you a general idea
06-23-2010, 10:53 AM | #30 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
This is fantastic! Thanks for the awesome info crfine and Rom3n.
Now just can't wait for the the VT2-500 . . .
Current Rides:
2022 ///M8 GC Comp Much enjoyed: 2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i |
06-24-2010, 02:21 AM | #31 |
Rep 5,329
please please keep us updated with this, ive just ordered this kit for my z4mr. can you hear the bypass valve under normal conditions? if you had to rate the quality of the actual kit 10 being the highest, where would you put this? are you noticing any higher oil temps?? im hoping with the low psi kit i wont need oil cooler mods ect ect
06-24-2010, 07:37 AM | #32 | |
Rep 2,747
Quality: I compare the ESS components to the stock parts replaced. I did not want anything over the top and flashy, but rather something that was more in tune with the clean stock look. That being said, I rate the quality a 10 out of 10. I know this is a high rating, but the ESS components are on par or better than the quality of OEM. I have not had any issues with higher oil temps, and don't anticipate that I will with the low boost. The real test will be when I put the car on the track though.
06-24-2010, 08:05 AM | #33 | |
Rep 5,329
byron |
06-24-2010, 10:16 AM | #34 |
instagram 997turbotom
286
Rep 7,377
ESS did a lot of track and high temp testing with the stage 1 kit with no issues. From my reading, people are having heat issues with stage 2, but thats still in development
06-25-2010, 06:19 AM | #40 |
Rep 1,557
Maybe the problem with stage 2 is that the oil cooler needs to be re-located to make room for the I/C ? I was running a gen 1 stage 3 on my M3 but that had enough room for the heat exchanger to sit in front of the OEM oil cooler, the Z4 doesn`t.
I`m sure ESS will expand but a recent post from them stated that the stage 2 for Z4 was on hold, they`d already said before that post, that the Z4 550 kit wouldn`t happen this year. Maybe this now wont happen at all as the 550 kit needed a bigger I/C again. Maybe they`ll use the Gen 1 water/air set up as the heat exchanger is much smaller and could be fitted behind the kidney grills. |
06-25-2010, 03:57 PM | #42 | |
International Bar Hopper
25
Rep 350
Drives: 2006 Imola Red Z4 M Roadster
I just spoke with Roman this morning and my car will be ready very soon with the VT2-500 installed. There is no heat issue, the only problem is fitting the intercooler piping and tooling required. This is for GEN 2 VT2-500. This winter VT3 will be installed. |
06-25-2010, 04:49 PM | #43 |
391
Rep 3,149
The new VT series uses the Vortech V3 self lubricated blower. Unlike the previous CFR series that uses an ASA blower the Vortech does not share oil with the motor. This helps to keep oil temps down under all conditions with our intercooled and non-intercooled kits.
