Thread Tools |
| 06-29-2011, 11:36 AM | #1 |
Rep 11,671
New home alignment toy
I seem to spend a small fortune on alignments through the year.
So..... I bought a new toy to go with the corner balance scales. ![]() Longacre digital caster / camber gauge kit that reads to .1º (1/10º) camber and caster as high as needed. ![]()
nada
| 06-29-2011, 05:16 PM | #4 |
765
Rep 7,864
Nice!
Are you going to use the "down home beer cooler/laser" set-up for toe? Last edited by Finnegan; 06-29-2011 at 10:38 PM.. |
| 06-29-2011, 09:05 PM | #5 | |
Rep 11,671
It's the best way to get the thrust angle set.
nada
| 06-30-2011, 06:24 AM | #8 |
Rep 11,671
^Sure, no problem.
One of the biggest PITA things about DIY alignment is getting under the car to make adjustments. I'm in the process of having some load bearing car stands made up so that I can get under with the car still on the wheels. I'm also getting a string frame put together.
nada
| 06-30-2011, 01:43 PM | #9 |
Rep 11,671
Until I get around to it, this is a pretty good procedural write up.
The main difference for our car is the sequence. On a rear wheel drive , we would do the back camber/toe first. DIY 4 wheel alignment
nada
| 06-30-2011, 02:17 PM | #10 |
![]() 492
Rep 2,747
Damn, you've got all the cool toys.
Thanks for the link, looking forward to your write-up too
| Bookmarks |
