03-07-2015, 04:56 PM | #1 |
Rep 115
Removing the Resonators?
I'm considering an exhaust mod to remove the stock resonators and replace them with a magnaflow muffler. I want to make sure that I won't trigger any kind of check engine light by doing this. Can anyone confirm that removing the two resonators in the image below will not throw a light?
03-07-2015, 05:13 PM | #2 |
Rep 2,782
Those look like cats. As long as there are no O2 sensors behind them (it looks like there aren't), you should be fine.
03-07-2015, 07:53 PM | #3 |
enthusiast
48
Rep 1,695
Those are your cats. The ones down stream at the X is your resonator.
It is good that you asked us first or you would have been screwed. |
03-07-2015, 08:06 PM | #4 |
Rep 115
There wasn't anything plugged into them. No O2 sensor that I could see. I thought they were either resonators or secondary cats that wouldn't throw a code if removed. Am I wrong?
03-07-2015, 10:55 PM | #6 |
Rep 115
Would it be possible to fit a Magnaflow muffler where the stock muffler currently sits? Most people seem to cut these two cats out and replace them with a Magnaflow.
I'm wondering if I can leave these cats alone and simply delete the resonator and replace the stock muffler with a Magnaflow. Want to make sure there is room. |
03-08-2015, 09:28 AM | #7 |
Rep 2,707
http://www.zpost.com/forums/showthre...ight=Angry+cop
This mod has been done many times Don't mess with the cats.
03-08-2015, 12:07 PM | #8 |
Rep 115
This is the exact mod I want to do. I will read through the entire thread later, but just skimming it I didn't see any complaints from the owner about removing the secondary cats. Someone tell me why I shouldn't do this.
