04-10-2023, 03:48 PM | #1 |
Rep 30
Replaced battery, but still getting ABS, Brake, & Traction lights flashing
Hey all -
I read through a bunch of the posts here and found that many people had issues with the ABS, Brake, & Traction control lights flashing while driving. I found many that said that replacing the battery fixed their issue. I replaced my battery today (old one was 3 years old) and then took it for a spirited drive. Everything seemed great and then 15 mins into the drive saw the lights flashing again. This time, they also had the battery light illuminate. I brought it into my garage and while the battery light was illuminated, I hooked up my Autel code scanner and noticed that the ECU was reporting approx. 12 - 12.2v while the car was on. I replaced my alternator voltage regulator a few weeks ago when I saw something similar and then after that the voltage was showing 14 - 14.5V when turned on. Could it be anything else or am I looking at a complete alternator replacement? If so, can you point me to the suggested one (non-OEM)? Thanks in advance! |
04-10-2023, 05:01 PM | #2 |
Rep 597
Any fault codes that they list here? https://modulemaster.com/products/bm...0e-abs-rebuild
GrayZ4MCoupe11.00 |
04-10-2023, 05:16 PM | #3 |
Rep 2,929
Drives: Anything
If you're still seeing under 13v with the engine running after replacing the voltage regulator and battery, then it's the alternator itself. Valeo, I believe is the only one you can buy brand new. All others, including OE BMW alternator, are remanufactured.
GrayZ4MCoupe11.00 |
04-10-2023, 09:52 PM | #4 | |
Rep 30
Thanks. I ordered one from RockAuto that's made by Valeo for $286 along with a new accessory belt. |
