04-15-2012, 06:17 PM | #1 |
Not a New Member
94
Rep 925
FOR SALE is a BMW Front Aero Cover painted in TiAg, with "mouth" painted in Sophisto Gray (aka Dark Metallic Gray). SOLD! now asking $305 plus freight this is $291 or more in savings over Tischer's price! * direct fit for all e85 and e86 (///m cars will need an updated light switch, fog lamp harness, and program in order to use the fog lamps) including: *top-notch painted bumper (done by a licensed BMW body shop, and matched exactly to the TiAg on my last Z4) *fog lamps ~ $180 value alone *lower center grille *roundel *complete DIY brake ducting + an extra set of uncut "ports" (so you can add your own personal touch). installation instructions here pics of the bumper installed on car here there are four scratches, 3 of which are in the paint only. the fourth is more of a scuff. two are surrounding the left brake duct. one is inside the left duct itself. the last is directly above the right brake duct. also, the lower, inner-most molded clip for the left kidney grille is damaged. pics of the damage... the ducts are paintable, but will require prep work to do so. they are also removeable, but you would need to purchase new filler grilles to plug the holes. this bumper does not have provisions for headlamp washer nozzles. this will be sold as a kit. i will not part-out. local pickup is recommended, but i will ship at your expense. i ran a general freight quote from Des Moines, IA to Beverly Hills via FedEx, and the cost came back at $199. so budget accordingly. less distance traveled will drop the shipping cost; the charge to 90210 is just an example (and worst-case scenario). and obviously, if you pick it up, there is no freight charge. edit: i can also deliver the bumper anywhere in Iowa for no charge. thanks for looking! -eric Last edited by v3.2mc; 10-17-2012 at 11:09 AM.. |
04-16-2012, 08:34 AM | #3 |
Not a New Member
94
Rep 925
^ i did consider that, but ultimately decided against it.
maybe Roffle will show us how it looks?
04-16-2012, 09:44 AM | #4 | |
instagram 997turbotom
286
Rep 7,377
04-16-2012, 10:10 AM | #5 | |
Not a New Member
94
Rep 925
backorder (plural backorders) 1. An order that cannot be currently filled or shipped, but is requested nonetheless for when the item becomes available again. 2. An opportunity to purchase other goods or services before the order is filled, and pick up a temporary second job to build up enough money just in time for the backordered goods to become available.
04-18-2012, 02:12 PM | #7 |
Not a New Member
94
Rep 925
hullo! to the top.
04-20-2012, 08:41 AM | #8 |
Not a New Member
94
Rep 925
04-23-2012, 12:29 PM | #9 |
Not a New Member
94
Rep 925
04-26-2012, 09:13 AM | #10 |
Not a New Member
94
Rep 925
updated price!
04-30-2012, 10:17 AM | #11 |
Not a New Member
94
Rep 925
05-04-2012, 09:57 PM | #12 |
Not a New Member
94
Rep 925
to the top
05-08-2012, 11:55 AM | #13 |
Not a New Member
94
Rep 925
bump! price drop.
05-18-2012, 05:25 PM | #14 |
Not a New Member
94
Rep 925
07-27-2012, 07:53 AM | #15 |
Not a New Member
94
Rep 925
hello! to the top.
09-08-2012, 06:44 PM | #17 |
Not a New Member
94
Rep 925
09-22-2012, 01:14 PM | #18 |
Not a New Member
94
Rep 925
10-17-2012, 11:07 AM | #19 |
Not a New Member
94
Rep 925
SOLD!
