      02-17-2016, 02:30 PM   #1
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
DIY Request: Valve Cover Gasket s54
Does anyone have the TIS or a DIY for changing out the valve cover gasket? I have a friend I normally do mechanical stuff with but I was just wanting to see if I could do it.
I searched the forums but couldn't find anything.
Thanks!
2021 m240i on order
      02-17-2016, 07:17 PM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Hope this is helpful:
http://blog.bavauto.com/13801/bmw-di...6-s50-s52-s54/
Salty
      02-27-2016, 04:07 PM   #3
SlickShift
SlickShift's Avatar
No_Country
325
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
And this will show you how to remove the valve cover from the S54.
http://www.m3forum.net/m3forum/showthread.php?t=450097
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      03-03-2016, 01:42 PM   #4
Steenos
2007 M Coupe  [0.00]
Dude Yes! Thank you Slick. Should I go ahead and change out the spark plugs too since I'm there? I'm at 87k. Not sure when they were done last.
2021 m240i on order
      03-03-2016, 01:56 PM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
You can do plugs anytime without removing the valve cover.
They are accessible under the trim cover.
But, if they have never been done; absolutely change them.
At the very least pop one out and have a look.
At that mileage I'm surprised that coil packs haven't also started to go.
      03-03-2016, 02:07 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
Have you checked the valve clearances?
Valve cover gasket is part of the job, and I always replace the plugs since I have to remove them anyway.
      03-05-2016, 10:26 AM   #7
Steenos
2007 M Coupe  [0.00]
Thanks Ian. I'll check em out.
Stick. At 90k I was going to go to a shop and have a valve adjustment done. I was just going to do the valve cover gasket myself just to have something to do.
2021 m240i on order
      03-05-2016, 10:43 AM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I agree with StickMon, hold off on the gasket until the valves are adjusted, it will be replaced at that time.
