Go Back   ZPOST > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      05-10-2024, 04:35 AM   #1
mongoose1951
Drives: BMW 330Ci BMW 435i
2004 BMW 330Ci engine noise
Hi,
On my 2004 330Ci with 220,000 miles.
When cold the engine makes a loud whine noise especially when accelerating, goes away when at operating temperature. Also there is a lot of mechanical noise inside the engine, goes away after engine is warm.
Big problem, or little problem?
Thanks
      05-10-2024, 07:49 AM   #2
tjbuggy2b
Drives: 2018 540i xDrive M Sport
Depends on the noise but I'm guessing it's not good, either way.
      05-10-2024, 09:26 AM   #3
CTSean
Drives: LCI BSM MT M2
Check the secondary air pump which should be easy to tell if the noise at start up and while cold is coming from it.
"Alot of mechanical noise" is not enough to really say anything. try and determine the source of the noise or maybe record a video and someone may be able to identify the noise.
