11-19-2010, 12:21 PM | #1 |
Rep 12,570
Front Grill Support / Bracket?
While washing the car the other day I noticed one of my grills is not secure, you can easily push it back, basically wont stay in place. Does anyone know what part locks the grill in place? Going to pull the bumper off anyway for other work so figured I might as well fix this while I'm at it..
Couldn't identify any part here (unless I'm looking at the wrong diagram): http://realoem.com/bmw/showparts.do?...47&hg=51&fg=15 Last edited by 3002 tii; 11-19-2010 at 12:32 PM.. |
11-19-2010, 01:28 PM | #2 |
Rep 146
Grills are one piece, little tabs on them can break off over time. Old car had this problem, exactly like you have described, right down to when washing the car they would pop out. Grills never fell out in the time i had the car so i never renewed them.
You could use it as an excuse to replace them with all black or carbon grills lol. |
11-19-2010, 01:45 PM | #3 | |
Rep 12,570
11-19-2010, 02:15 PM | #4 |
Rep 146
Only thing i can suggest is IF there is no broken tabs, then wrap some electrical tape round these tabs where they meet the bodywork to hold them in place with a better "bite" if you know what i mean.
11-19-2010, 10:28 PM | #5 |
Rep 12,570
So I popped out the grill, inspected the grills and tabs are all fine. What the problem is (as I suspected) is that there's plastic frame that sits behind the bumper that "accepts" the grill. That is the piece that's NOT secure. I inspected the other side and that side is secure and tight, but this side almost slips off or disconnects from the bumper.
I checked realoem but I couldn't find this piece... is this part of the bumper and cannot be bought separately? It would seem that you can or should be able to purchase this piece separately since I see how it slips on and off (there are these plastic "prongs" that the frame slides over)... Last edited by 3002 tii; 11-20-2010 at 11:01 AM.. |
11-20-2010, 11:28 AM | #6 |
Rep 12,570
bump for update, figured out what's wrong... anyone know if this piece can be purchased separately?
11-20-2010, 03:47 PM | #7 | |
Rep 421
When you install now put your fingers behind the part that came apart and squeeze it in with the grilled assuming you have it in line. |
11-20-2010, 03:56 PM | #8 | ||
Rep 12,570
That might sound right because I recall when I first purchased RPI scoops way back, I had trouble lining it up. So I later brought it to a shop while getting other work done and I recall the tech having difficulty with the grill, and I think he might have just used brute force to get it in... Quote:
11-20-2010, 05:07 PM | #9 | |
Rep 421
There are some pins coming from the bumper that the black piece goes onto. And the metal pushes down the pins to hold it on. When I gued it where the pins were it still came apart. So I glued the front of the black piece to the bumper. From that with the squeeze no problem. |
11-20-2010, 08:41 PM | #10 |
Rep 12,570
Ahh gotcha, same problem I have nothing keeping the frame from sliding off those pins. I will glue them down, thanks Ron!
06-18-2012, 08:54 AM | #11 |
Rep 2,460
Well I am having the exact same problems except I believe I am screWed because the mounting bracket thing is broken my grills are new because I got them in the mail but the mount is broken on 1 of the sides
06-18-2012, 09:07 AM | #12 |
Rep 12,570
Just glue the bracket back to the bumper, that's what I did. Works fine...
06-18-2012, 10:06 AM | #14 |
Rep 12,570
