03-02-2008, 10:19 AM | #1 |
Rep 30
Torque specs for wheels
Does anyone know how many pounds of torque are recommended when tightening the bolts on the wheels of a 3.0i BMW z4?
Thanks. |
03-02-2008, 12:57 PM | #4 |
Rep 666
110N*m to 130N*m
TIS calls out 120N*m plus or minus 10N*m. That's 81ft/Lbs to 96ft/Lbs. Most 1/2 inch drive clicker-type torque wrenches aren't that accurate anyway so pick your number somewhere in the range.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
03-03-2008, 01:34 PM | #7 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
88ft-lbs
03-03-2008, 05:12 PM | #8 |
My favorite sign.
169
Rep 4,333
1 million ft-lbs!!! hahaha JK
03-10-2008, 02:31 AM | #10 |
Rep 10
Always better to have tight nuts then loose nuts
05-05-2008, 01:48 PM | #12 |
gone baby gone
382
Rep 1,052
Dammits reply was clearly the most helpful. Seriously what value does that add?
Just piling on, I keep my wheel torque wrench at 85lbs, and also remember to tighten them in a star pattern to help avoid them loosening over time. More force is NOT always better, as you can be damaging the lug or its seat in the wheel if you over-tighten it. If you do that, they are eventually going to work loose anyway. Or the worst case scenario, which is shearing off a lug. |
06-10-2008, 07:31 PM | #14 |
Rep 238
I would presume that the torque spec is for dry (no oil) threads. Since the whole purpose of torque is to tension the stud, wet (oily) threads can result in as much as 40% more tension than dry. Depending on the design factor, this may cause the bolt to fail in shear when tightening.
If your bolts are rusty, it is ok to clean them up with some oil - just make sure you dry the threads before tightening. |
06-10-2008, 10:05 PM | #15 | |
Rep 1,269
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
06-11-2008, 08:15 AM | #16 |
My favorite sign.
169
Rep 4,333
I hadn't seen this post before.
