      03-12-2008, 10:32 AM   #1
ZEEFOUR
Drives: 03 Z4 3.0i, 03 MB E55 AMG
Does your Z4 start smoothly after....
I've notice twice now that after my Z4 sat about 4-5 days without starting, that when i started it, it idled really rough, almost like it was running on 3 cylinders and eventually the "check engine" came on. Each time i turned the car off for a few seconds, restarted and it ran fine. Anyone else expirience this? Car is always garaged...
      03-12-2008, 10:33 AM   #2
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Try using some oil stabilizer if you're going to let it sit?
Anyway you can scan the engine for the codes?
If you can get the check engine codes, it would be ideal for diagnosing your problem.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
      03-12-2008, 10:38 AM   #3
ZEEFOUR
Its my commuter so i drive it almost everyday, i went to daytona for bike week, so it sat for 5 days. I'll see if any codes are displayed...
      03-12-2008, 10:40 AM   #4
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
I let my car sit for 3-4 days @ a time. It struggles for about a second then it stabalizes right away. No check engine.
      03-12-2008, 11:29 AM   #5
scottmcke
scottmcke's Avatar
Drives: 2004 BMW Z4 3.0i
2004 Z4 3.0i  [7.00]
Mine can sit for a week or so (not by choice, out of town too much) and I have no troubles starting it when I get back.
      03-12-2008, 11:51 AM   #6
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Mine usually needs some revs when it starts after sitting...which it does a lot of...I rev it up to 3000 for a few seconds and it's usually ok...just needs a little wake up juice...
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      03-12-2008, 11:53 AM   #7
Hawkeye
Hawkeye's Avatar
No_Country
2070
Mine sat for a month and a half ( I started it once in between for the sake of switching the spot on the tires it was sitting on)
I have not experienced any of the said problems either. Every now and then when I start it will fluctuate RPMs. I don't think it is anything to worry about though.
      03-12-2008, 04:12 PM   #8
shiyan
has no social skills
shiyan's Avatar
19
Drives: 2003 Z4 3.0 Roadster
How do you see the engine codes?
      03-12-2008, 07:29 PM   #9
em2b96p
Drives: cbr600rr
same exact thing with my Z
      03-12-2008, 07:44 PM   #10
CherryZz
Drives: Z4M
i had this happen to my other bmw. when i took it to service, they checked the engine log, and told me that one of the cylinder misfired. i rmb they replaced something.... but can't rmb what exactly.. happened few years ago... so yea... my best advice for you is get it to ur dealer and have them check the logs.
      03-13-2008, 01:17 AM   #11
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
OBD2 scanner.
I have one specific to VW's and it works wonders as I can log engine activity while driving, fault codes, throttle body adaptations, etc...
but I've yet to buy one for my BMW. Haven't found one as powerful as my VW one.
2006 VW Jetta 2.5
Once upon a time...
      03-13-2008, 10:49 AM   #12
ZEEFOUR
Thanks, I think that may be the cure....
      03-13-2008, 10:55 AM   #13
FloridaBoy
FloridaBoy's Avatar
19
Drives: 2005 Z4 3.oi
Nope, car always starts fine... even after several days of storage.
2005 3.0i, Black Sapphire, SMG, Navigation, Heated leather, iPod w/Dice, Carver Subs, Sport, Foamless SG, 3M Clear Bra, Sirius, 18 inch 107's
      03-13-2008, 11:29 AM   #14
Reach
gone baby gone
382
Drives: 2016 F80
Just get a cheap OBDII scanner, you don't need the super-duper integrated code visual readout ones that are specific to each module.
I got a $35 one off Amazon that I use on all my cars and any of my friends that throw a code. It just reads you the code #, and it comes with a lookup book with universal and manufacturer specific codes to de-code what it really means. Anything more specific, like model specific stuff BMW does, can be looked up on the internet.
All you need is something that can read and clear codes. Clearing them will reset the CEL on your dash. But of course it does not eliminate any underlying problems, so if this is a chronic thing, your code will come back until you fix it.
      03-13-2008, 11:30 AM   #15
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
182
Drives: Z4M
its called a cold start people. I usually let me car idle down to about 1k before heading out.
      03-15-2008, 05:58 PM   #16
roh92cp
Drives: 03 3.0 z4
I have an 03 with 45k and I noticed when its cold below 40 degrees it sometimes starts then stalls right out. The second time it starts back up and hold idle. Dealer checked it and said nothing was wrong no codes and it needed injector cleaner. I never did the injector claener as I thought that was total crap and I would have had to change my oil after.
      03-16-2008, 05:24 PM   #17
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
Why would you need to change your oil after using injector cleaner? Weak start in the cold can be spark plugs if they haven't been changed yet, or maybe car battery isn't providing enough CCA.
2006 VW Jetta 2.5
Once upon a time...
      03-17-2008, 10:31 AM   #18
ZEEFOUR
Why would you need to change your oil after using injector cleaner? .
I've heard that before, some people say it dillutes the oil, i'm a believer in injector cleaner, been using it since 1988 when carbon buildup was really bad on fuel injected cars. I use it 1K miles before oil changes to be on the safe side....
      03-17-2008, 10:42 AM   #19
caseysc
caseysc's Avatar
Drives: 2010 128i Conv.
2005 Z4 2.5i  [8.00]
I often leave mine at the airport for 4 days. Never had a problem.
