09-02-2016, 05:28 PM | #1 |
Rep 918
Fuel starvation during cornering?
Do you guys experience any starvation issues due to the single pump located on one side of the tank? Particularly, guys who road race and run supercharged setups?
Read about the E36 M3 guys installing dual pumps, one on each side of the fuel tank (obviously not possible on Z4) to alleviate this issue. Also, does anyone know what type of fuel pump is used in Z4/Z4M, and the flow rate of the pump? I took a look at one saw a serial number with no other markings.
Andre - 2J into a Z4 Coupe!
09-05-2016, 10:22 AM | #2 |
Rep 758
No supercharger, but I haven't seen any issues so far. At Daytona on the 30 degree banks with 1/2 tank of fuel I didn't have any issues, and I've been on the Daytona infield course with the low fuel light on without an issue. I'm not pulling fuel with the stock 3.0si at the rate you'd see with a boosted engine, but at least it's a data point.
Top Down 365
10-03-2016, 02:07 PM | #3 |
Rep 59
Don't know about the "M", but the stock Z4 is equipped with a siphon in the tank to transfer fuel to fuel pump side. I've been on road courses and had no issues with less than one-quarter tank.
10-03-2016, 07:14 PM | #4 |
Rep 233
Yes I'm experiencing this now at the track under half a tank. I ran my tank on fumes on two occasions at the track before this problem occurred so I have a pump on order. I will report the results as soon as it's in and I'm back to the track.
inTgr8r2434.50 |
10-20-2016, 01:27 PM | #7 | |
Rep 11,669
Is there a better way to keep it in place?
10-20-2016, 07:58 PM | #8 |
Rep 233
Hey Ian,
You probably just read about my issue twice as this is the second thread I posted this in. I'm still puzzled about how this happened. I don't think this will be a common problem as it shouldn't come un-clipped that easily. I think my situation was an anomaly. |
10-21-2016, 08:21 AM | #9 | |
Rep 11,669
10-19-2020, 08:32 AM | #10 |
Rep 918
Minor update - as my power levels increased and my g-forces increased (stickier tires), this issue has been getting worse. Since I'm running quite a bit of fuel to feed the monster, anything under 3/4 tank will starve at specific corners at specific tracks, like clockwork.
I'm not a fan of installing an accumulator with secondary pump, although I fear that's my only recourse. Anyone have additional insight on Z4 solutions to keep the fuel pump happy? It's possible the fuel feed tube from the driver side of the tank isn't connected or somehow cracked but I don't remember that being an issue. Wish I could see a cut away of the tank to figure out solutions
10-19-2020, 02:20 PM | #11 | |
Rep 1,373
I wonder if this might be my issue... recently after doing an airbox and a crap ton of new suspension mods (MCS 2way remotes, pretty much everything solid) I am starting to get a hick-up during extremely high G corners. Car is totally fine everywhere else except those high G corners. I am just going to bite the bullet and replace the pump. I'll report back with how I find the old pump when I pop open the tank.
07 Z4 M Coupe AW/IR |
10-19-2020, 08:55 PM | #12 |
Rep 405
Not ideal, but wonder if a surge tank is needed to keep up with the gs you are seeing. Radium makes a slick kit for the m3s
http://www.radiumauto.com/Fuel-Surge...esM3-P305.aspx |
10-20-2020, 08:38 AM | #13 | |
Rep 1,373
At the very least the car could probably use a new pump/filter. I have never changed the pump and had the car since new so I am sure its getting a bit tired. The fuel filter is integrated with the pump so i am sure that needs a change too after 86K miles I'll also do some data logging this weekend and see if I confirm it is fuel starvation.
10-21-2020, 12:45 AM | #14 | |
Rep 1,923
10-21-2020, 06:34 AM | #15 |
Rep 485
My experience with my track MCoupe is that the fuel system scavenges every drop of fuel before it shows the first sign of starvation. In fact, I have run it out of fuel on two occasions. Both times I got about 3 seconds of run time after the first sign of starvation and then I was coasting. My old E36 racecar with dual pumps could be run for 10 minutes starving on fuel.
Maybe the difference is in the shape of the tank...? |
10-21-2020, 07:38 PM | #16 | |
Rep 918
If you're stock, then I can see this being some other issue possible... the Z4M fuel pump has a bucket that itself traps fuel but it only holds so much in there before it has to rely on the feed. As a data point, I suck down 5.5 gal of fuel in a 20 minute lapping session which is roughly 1:30 per lap (2.25miles), or 30miles. Shit.. like 6MPG lol Turbos are very thirsty. I can see the fuel gauge drop a hair after every long pull! Now it's quite possible that the lines connecting to the other side of the tank somehow have ruptured or cracked and thus it's not properly pulling in fuel from that end. I could look into that but not sure of the best method to test it. Also, my fuel pump assembly is only 2 years old, only a few thousand miles on it. https://www.zpost.com/forums/showthread.php?t=844672 Guy above seems to have similar issues, with Supercharger installed Found a diagram: http://www.unofficialbmw.com/images/...20Part%202.pdf page 2/3 onward. If you look at the diagram on page 27, you can see the pump sits inside a bucket. On high-g right turns, that bucket will have just enough fuel for a period of time. It's possible I eat through all of it quickly, leaving me with no return fuel to siphon up more fuel from the other side of the tank. Matter of fact, I'm running the pump at full 72psi which means there is little fuel being returned to the other tank, making the siphon even less effective. If I part-throttle through the turn, there is a lot more fuel returning, which keeps the siphon going. AND, I just stumbled onto this: Go to about 4:30. It seems funny the Aeromotive guy is talking about "road racer with a saddle tank who's oem syphon jet wasn't working well enough". It's $270 for their syphon kit btw...
10-21-2020, 09:18 PM | #17 |
Rep 485
You’re burning about 50% more fuel than me. No doubt that’s the issue. I wonder now if one is to burn E85 if this issue will rise up. Fuel consumption is said to increase 25-30%.
10-18-2021, 10:30 AM | #18 | |
Rep 1,373
I never changed the pump/filter and I just clicked over 90K miles so that is going to be the first course of action along with getting the injectors cleaned. I'll let everyone know if I find the pump not attached correctly.
10-18-2021, 12:09 PM | #19 |
Rep 918
It's not just you. I noticed similar experience on Lightning coming into T1 from high speed straight. I think the combination of heavy braking (gas goes towards front of tank) and then tight-right turn OVER a crest, all contributes to the fuel pump starving, even on a full tank. I always get a sputter when I'm on the gas after T1.
My solution is part throttle it for just 1-2 seconds after T1, then go full, and it goes away. I have a venturi "upgrade" to try someday and see if that reduces the issue. For now at least, every single session I do on any track requires me to start with a full tank for the least amount of disruption. That reduces it. In Pocono NORTH, the long tri-oval I'm flat out and don't get fuel starvation, which is odd in itself. I have no explanation. I have a feeling our best solution here is to use a small fuel accumulator. I had to so something for my Meth injection because my meth pump would start from high Gs and the meth tanks sloshing the meth all to one side, starving the tank outlet. I created a small cylinder about the size of a soda can that sits lower than the tanks. There is always meth in there. When the meth tanks start to starve, there is enough in the 'soda can' to run meth for about 10 seconds of boost. By that time, the meth from the tanks will start filling it up again with gravity.
10-19-2021, 07:04 AM | #20 |
Rep 485
I’m going to opinion that y’all have a fuel system malfunction. I’m scooting around the track pretty hard (1:33’s at Road Atlanta) and have zero fuel starvation issues. As stated above, only when run to empty do I have any starvation (and then it’s game over!).
Even with the higher fuel consumption rate, you shouldn’t have starvation. I would start by replacing everything in the tank (pump/filter and regulator). Verify everything is attached properly and go from there. |
10-19-2021, 07:14 AM | #21 |
Rep 918
To add: my pump/filt/reg are all new-ish. Is there possibility of a clog or disconnect of the venturi on the driver side of the tank? Not sure how to check other than drain the tank and try to reach over with my arm.
10-19-2021, 09:43 AM | #22 | |||
Rep 1,373
I think at the very least I am going to fall in your foot steps and replace everything in the fuel system and see if that cures the problem.
