12-23-2022, 02:34 PM | #1 |
Rep 45
Questions about spacers
Hello,
I’m planning on running H&R 10mm spacers all around. Suspension will be Bilstein b16 and oem style 224 wheels. From what I’ve read, 10mm spacers are fine, but will I need hub extenders for the fronts? Thanks |
12-23-2022, 03:39 PM | #2 | |
Rep 2,706
No affiliation. https://www.ecstuning.com/b-h-and-r-...-pair/2075725/
12-25-2022, 07:56 AM | #4 | |
dances with roads
4773
Rep 4,102
12-25-2022, 08:09 AM | #5 | |
Rep 2,706
Have a good day.
12-26-2022, 08:00 PM | #6 |
Rep 50
The H&R spacers are quite good stuff. I have a set on my E30 M3, and have used then for driving around and 300+ track days.
In the meantime, I found these guys, and use their spacers on my M Coupe track car: https://www.42draftdesigns.com/ Especially, with spacers, forget bolts. Go with studs as they make mounting a piece of cake. Bimmerworld has Italian-made studs which are great. You see the 300+ track days on my M3? Those are all on the same Bimmerworld studs. Nary a failure if you follow the installation instructions and torque your wheels properly. |
