      05-19-2012, 10:28 AM   #1
SILLY
Drives: Black 3.0i Z4 2006 Roadster
Dash scratch
Hey everyone. New to the site, but been reading it for awhile. Just wanted to know if anyone has found a way to remove or reduce scratches in the stainless dash? Previous owners must have laid something on the seat that touched the dash, and left "wiggly" lines behind as the item slid around. Most noticable in sunlight, so they're not that deep. Thanks...
      05-24-2012, 09:49 PM   #2
J_Riebold
Drives: 2006 BMW Z4 M Coupe
Hi Silly, I actually just encountered this problem today. The dash is actually aluminum and you can use a scotch brite pad to help reduce the scratches. Just ensure that you go in the direction of the grain because it is after all brushed aluminum.
      05-30-2012, 02:40 PM   #3
SILLY
I don't get to check email often, so that's why it's been a while to get your response. Thanks for the info, I'll try it out for sure. Good thing is, they aren't deep scratches.
      05-30-2012, 03:45 PM   #4
DataStream18
Drives: 2003 ESS TS1 Z4
You could always do a 3M Di-Noc wrap or something similar.
Also where in Michigan you from?
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
      06-05-2012, 03:27 AM   #5
tortlZ4
Drives: BMW Z4 3.0is
2006 BMW Z4  [0.00]
where?!?!?
Hey! that looks sick!!! where did you get that done? or where did you get the parts and everything! i would love to do that to my Z!
      06-05-2012, 06:01 PM   #6
DataStream18
I did it my self, I'm the local goto guy for interior and exterior wraps. I went to pyspeed.com and picked it up. Also stickercity.com has the best deal for the larger amount like for our entire car.
      06-06-2012, 11:00 AM   #7
SILLY
The wrap is always an option. Hopefully they will come out, since they aren't deep. I am from Midland Mich. Thanks.
      06-06-2012, 11:45 AM   #8
txz4
txz4's Avatar
60
Drives: 2006 M coupe
i dont recall where, but there is a DIY floating around on a step by step repair for this.
      06-23-2012, 04:50 PM   #9
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
Luv ur seat color
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
