      04-19-2020, 12:10 PM   #1
maupineda
Drives: E86 Z4MC
Help From Z4M Owers with Cruise Control and INPA
Hi there. I am toubleshooting my CC which is inop since I got the car. I found in INPA the page to test the switches and I am finding something strange
Can anyone with a Z4M equipped with a working CC and INPA check the following page to see what is the default status on your car?
AS you can see, in my case the car is defaulting to clutch switch on, and I don't know if this is the correct default state. the more strange thing is that even when I disconnect the switch from the harness the status does not change. I am trying this with the engine off and ignition on, I cannot start the car as I have the vanos solenoids off.
To go to this page you need to:
a) go to the engine DME module
b) press F6 to read status
c) Press F1 to read digital values
d) press f1 to check the switch state
c) press f3 and it will provide the following page
The above page shows the status of conditions that may prevent the CC from working, either normal or abnormal. before resetting the page I had a "JA" value under the clutch switch value, and would not know if that was good or not.
BTW, I have a new sensor, but again, even with the new one the status defaults to ON
