Originally Posted by pbdm4k
Sensors are for people who don't look at their brakes...
To get rid of the brake sensor:
1.) Locate your brake sensor.
2.) Cut off the brake sensor.
3.) Notice there are two wires for your sensor and expose the copper wire a bit.
4.) Wrap the two wires together.
5.) Cover with electric tape.
Tada, no warning brake light. No sensor.
BUT MAKE SURE YOU CHECK YOUR BRAKES REGULARLY IF YOU DO THIS.
Or to make sure you never have to worry about the sensor just pop them out of their mounts (before they're "worn" obviously) and zip-tie them up out of the way so the sensor can't get damaged
But as stated above "MAKE SURE YOU CHECK YOUR BRAKES REGULARLY IF YOU DO THIS"
