      12-05-2016, 05:19 PM   #49
Expert@ApexWheels
Expert@ApexWheels's Avatar
3539
Drives: M3
Originally Posted by SDCoupe View Post
I'm looking for an aggressive setup for a stock Z4MC. I don't want to need camber plates or spacers or to modify the fenders. I already have the 9.5x18 et22 rim for the rear. The tire of choice for me is the Michelin PSS. From what I've read, a 265/40 or a 275/40 will fit on the rear. What rim and tire size could I use for the front?
Typically for a direct fit, we recommend the following fitment for your Z4M:
18" Staggered:
F: 18x8.5" ET38 (Profile 1) - 235/40-18
R: 18x9.5 et22 (Profile 3) - 265/35-18 or 275/35-18
For customers wanting to run a concave wheel up front, then we recommend the following fitment:
F: 18x9" ET30 - 235/40-18
R: 18x9.5" ET22 - 265/35-18 or 275/35-18
The front will be close to the outer fenders on the Z4M, but it may work with 235/40-18 tires. It would require around -1.8 degrees of camber or more up front.
-Matt
