      02-26-2010, 12:59 AM   #35
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
Originally Posted by O-cha View Post
I've always felt that the car wants to rotate more when I end up braking at really low revs or with the clutch in.
Do I understand you are depressing the clutch in the corner in order to rotate the car? I use trailing-throttle-oversteer to rotate through corners and have tuned the suspension in order to accomplish this. The only time I am on the clutch is changing gears. Balancing the car through the corner modulating the throttle is my driving style. One of many fundamentals I was taught by a pro race driver was to put the car into the proper gear BEFORE entering a corner--this includes clutch depression. I'm not saying what you are doing is necessarily wrong, just not what I learned and not my style. I would think using trailing-throttle oversteer would rotate the car more than simply depressing the clutch.
You have to be 100% behind someone before you can stab them in the back.
David Brent
