DaveJB, I'm in the middle of installing the FA 500 kit and have a couple of questions. Did your rear spring perch have a threaded part with a nut on one end? I don't recall seeing any other rear spring perch looking like this for our cars. I'm guessing the the perch goes on top of the spring, but I'm not sure if the threaded portion gets attached to the car somewhere. I always thought that the spring perch was sandwiched in on top of the spring.
Also did you notice if you can actually make adjustments to your camber plates? Mine looks like I will have to saw off part of the hex wrench to allow it to loosen the locking screws.
Thanks,
Jim
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
