Originally Posted by DanFromTucson
What size wheels would you recommend if we wanted to run 245 / 275 tires front / rear without rubbing (I run Pilot Super Sports)?
EDIT: I'm on stock Z4M Coupe suspension (stock height and camber).
Dan,
Since you are running stock suspension and camber I would recommend an 18x8.5 ET35 for the front and an 18x9.5 ET22 for the rear. The 10" wheel is 3-4mm more aggressive towards the fender than the 9.5" wheel. We had some customers who ran the 10" ET25 with 275/35's who had some fender rubbing. If you really want no rubbing and 275's than you should run 9.5" ET22's. Some 275/35 extreme performance summer tires and R-comps may rub but if you are running a less aggressive summer tire such as a Hankook V12 than there is less likelihood of rubbing.
