Originally Posted by mfanatic325
Can someone enlighten me as to what benefits there are for swapping out the OE links?
Originally Posted by itdnwiwbp
I'm no suspension expert but it's my understanding that to properly corner balance a vehicle with coilovers adjustable end links are necessary to remove the preload from the swaybars. I'm sure someone else with more technical knowledge can chime in with a more detailed answer.
Yes it's for corner balancing.
Do the corner balance with endlink disconnected then when done reinstall.
- adjust endlink for Swaybar angle and zero load (s.bar is in neutral position)
