      02-02-2013, 11:11 AM   #15
aerobod
Car Geek
aerobod's Avatar
3709
Drives: Caterham R500, M2-G87, Macan S
Originally Posted by kennyfrc View Post
Compare the HTHS of Redline to TWS!
6.7 vs 5.2 mPA.s? http://www.tds.castrol.com.au/pdf%5C...63_2011_10.pdf
TWS has always been at the low end of the "60" weight scale. Redline is definitely more viscous across the range, but also will have lower flow rates and potentially higher temperatures and pressures due to it's properties. The question is, is 5.2 mPa.s good enough under high stress levels?
