      04-17-2013, 04:25 PM   #13
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by ludoZ4 View Post
nobody can help ?
From what I gather in this thread, this is the SMG transmission, and very few (if any) of us have that transmission. If this is indeed the SMG, you might get more input from an E46 M3 crowd since the SMG box was used quite a bit on the E46 M3.
If I had to guess, I'd think the module/controller has issues, or the shift lever isn't triggering the right mode (manual vs. auto) which could be a contact/switch issue in the shifter mechanism. Since it works sometimes, and since modules using fail 100%, it may be a shift level/contact/switch issue.
Access to a diagnostic tool to read any codes the ECU is recording would go a long way to helping you figure out where the issue is.
