Originally Posted by nekky
Just finished it. Was kind of a combination of both.
Worked from the top to get everything off, unclip the wire, etc.. Then got the O2 sensor socket (22mm) on and used a swivel adapter to finish it off.
Another question: Now that the car has the fresh O2 sensor, and I've cleared the codes from the DME, how long will it take for me to notice a difference in drivability? Should it be right away? It seems to idle better, but still died once driving around the lot.
Nekky-
Installed AA header over winter. Drove it for first time 2 days ago.. Took it out on the fwy and got a bunch of Cels when I hit the sport button.
P1633
P114B
P2198
P2270
P0174
P0430
Seems crazy to me that headers would do all this.
What did you find solved your issue _ I am close to pulling the trigger on ESS525.. If I need a tune I mine as well do it now.
Chip
