      11-12-2012, 12:07 PM   #11
David70
Drives: 06 Z4M Coupe - 13 Cadillac ATS
I think both look good but prefer the ARC-8's.
I was considering the 9" front wheel with 245 tire. With your 235 tire you thought you could do it without a spacer but would the 245 tire require the spacer (or your best guess). I thought the wider tire might change how much space is available. I would prefer to avoid spacers.
Also, with any spacer fitting requirement, if the wheel was available in the correct offset it wouldn't be needed, correct?
