Originally Posted by el_capitan
Just curious- the speaker grilles are removable? THey just pop off without removing the card?
Pardon the thread disruption OP
Don't pry too hard they will be brittle
There are 3 or 4 tabs holding the grille in place.
Slide a blade behind the grille flange and feel around until you hit the tab, depress the tab and work your way around the others, should pop out after 2 of the tabs are depressed.
