Ran into a roadblock today:
Aristo 2JZ throttle body is drive-by-wire (not cable controlled)
Z4 throttle pedal is electronic
All is good, except the Z4 pedal voltage values are not correct with respect to what the 2JZ ecu wants to see, and controlling the 2J throttle body isn't cake.
I can go to a cable throttle body from the US MKIV, but after looking around, can't find anything that will fit the Z4 for cable operation.
If any of you know of a gas pedal which can be swapped with cable control, let me know!
