      08-10-2016, 02:20 PM   #26
dre99gsx
Drives: 1994 Toyota Supra
Disassembly - crud on the head cam caps
Lots of carbon deposits on valves, head bowls and piston tops
Cleaned most of it up
Checking for flatness with a precision straight edge
Washed the block, ready for assembly
Engine seems healthy without going into further measurements for bottom end. Valve stems looked clean and dry, don't think valve seals will need to be replaced. Ordered a bunch of o-rings and gaskets, using an old oil pump/water pump I have from a previous build, new headgasket, ARP studs, and buttoning her back up. Keeping it simple and budget for now.
