Don't know the oil plumbing on these things, but if it isn't found in the oil pan, then what?
Again, not knowing the intimate details of these things, but having messed with a lot of engines in my life, I would spend a little time trying to drag the bottom of the oil pan with it on via the drain hole before I took it off. Sounds silly maybe, but a fine piece of stiff wire, etc, you know the clothes hanger method???
Who knows 5 minutes and you might get lucky??? Or perhaps it is heavily baffled and it might be a waste of time....
