If it is not a sticky piston in the caliper, I would say it is more an issue with the floating of the brake caliper. They sit on slide pins so then can center as they apply force, these can get dirty and sticky and cause improper engagment/dis-engagment of the brakes. They are also super easy to check and lubricate.
