      02-10-2010, 08:52 AM   #30
Starscream
Starscream's Avatar
Drives: ///M Roadster + E92 335i 6MT
Originally Posted by 03BeastCharmer View Post
On my ZCP I don't run spacers, but to run stock front track width you would need a 5mm spacer. Without spacers, the fronts look a little sunken.
Originally Posted by F360C View Post
Yu can run them just fine with out spacers but the front ZCP wheel is not the same offset as the OEM Z4M front wheel so it is a little sunken in. I think a 10mm spacer makes it look good but I went with a 15mm based on the recommendations from Rogue Engineering. I think the 15mm makes it look perfect but you couldn't run the 15mm with a stock alignment. It needs extra front camber so the wheel doesn't rub which is not a problem for me since I run -2.5ish. As far as the rear goes they look fine with out spacers but a 5mm spacer would make it look perfect. I was going to buy a 5mm spacer for the rear but I ended up picking up a set of 285 rear tires for stupid cheap to replace my worn 275s and I think the 285 will fill the arch just perfect with out the spacer
Thanks Guys,
Have to decide if I should get these or a new exhaust,
then begs the question on what exhaust to get!
I don't want too loud so from research I'm thinking Remus, or SS powerloop,
I just really have a thing for the CSL's
Imola Red Roadster
