Originally Posted by Beedub
wheels look awesome and these sizes "seem" to be rub free.... but what i dont get, is you got rub with your e92 18s that were less aggressive??
secondly im wondering how the front clearance will be with a coilover equip car, my car has a et 34 on an 8.5" wide rim and i only have 4mm clearance between the rim and the perch on my clubsports...... im wondering if the 9" wide wheel with et 31 will make this worse, better or the same.
With the E92 wheels I had 265/40 rears - so going to 275/35 solved that issue.
As for front rub I've had the Turner camber shim kit installed and am running as much negative camber as I can, so even though the EC-7s stick out 4mm more I haven't had any rubbing.
If you ran this offset (9" ET31) on front you'd have 3mm less clearance between rim and perch theoretically compared to your current setup
