Originally Posted by BruceJ
Of those that drilled, how did you determine where to drill?
Pull bumper off the car and set it on the the Mstache or put the Mstache in place with tape and guess?
Thanks in Advance
Placed it up to bumper and had it rest on wooden blocks and did the best i could to estimate where to drill. Make the hole a little bigger, more like a slot to help with aligning it. Dont make it wider than the bolt washer though. Then double sided tap the bottomand done.
