      04-04-2013, 12:19 PM   #59
ApexWheels
ApexWheels's Avatar
1423
Drives: M3
Originally Posted by lrcigar View Post
I have a 2003 2.5i non m, and non sport. Already have the ARC-8's 18x8.5" ET38 front, and 18x9" ET42 rear. I have Hankook Ventus V12's 225/40/18 on the front, and 255/35/18 V12's on the rears. Since then I installed HR coilovers and lowered the car. The way it sits now there's no rubbing. I would like to replace the tires with Ventus V12's 235/40/18 front and 265/35/18 rears. In your products detail for non M's it says that the 235/40/18 can be used in the front and 265/35/18 can be used in the rear depending on the tire. Do you think there may be an issue because the car was lowered? The coilovers are adjustable so I can make changes as needed.
thanks
With your current wheel sizes and the Hankook V12's in 235/40/18 and 265/35/18 I do not foresee problems or rubbing even when you are stepping up to those larger sizes. We actually recommend using those tire sizes right from the start and they will fit much better on your wheels than the narrower set up you had before.
